Old 05-05-2011   #1
93gtpeater
Drives: cbr 1000rr repsol
Angry 1g awd tranny install
Ok so I pullied my tranny out of my tonight. It came out pretty easy. I have done a hand full of transmissions on dsms but this car is hell for me. The trany sleds right out. Go to put new one in and it just wont fit. I keep geting stuck on the rear cradle. I just cant figure out how to get up and in on to the motor. Last time I had to pull the rear motor mount and jack the motor up to get the tranny in. anybody have a sercet?
Old 05-05-2011   #2
Re: 1g awd tranny install
just keep wiggling it, if it came out it will go in.
Sorry I'm not more specific but its been a while since I've done one, but I do remember having the same troubles, just rotate the trans a lot and it will squeeze by.
Old 05-05-2011   #3
LingLing
AznKraut
LingLing's Avatar
It's easier if you jack the trans up from the bottom with it rotated upwards so the center diff is angled up. This helps preventing you from getting hung up on the rear subframe.
Old 05-06-2011   #4
Diff up and in first, rotate it up into place.
Old 05-06-2011   #5
There is a triangle shaped bracket held on by 5 bolts in the front K member, remove this and it should slide in.
Old 05-06-2011   #6
93gtpeater
I got the tranny in. I had to unbolt two of the motor mounts and jack the motor uo tho get it in. it was a nightmare. Just need to bolt everything up and hope this tranny works. Thanks for the help guys
