Old 05-09-2011   #1
93gtpeater
Drives: cbr 1000rr repsol
Beater 1g
I figured I would make a project thread for the talon. I bought it about 2 years ago and have put about 30 miles on it. When I bought the car it came with a 16g but turned out to be a 14b.
Mods when I bought the car
Ghetto fmic
3 inch turbo back
Evo fuel pump
Safc
Wideband
When driving the car home the turbo froze up. So bought a scm61 to replace the blown 14b. when installing the new turbo the oil pan was messed up. so I went to replace the oil pan I pullied the t case off and the output shaft came out with the t case. So replaced the tranny from one I got from trk permance and it didnt make it down my road. The bearings were toast in it. Found a rebuilt tranny put it in and drove it a couple miles on it and the motor started making noise. So I picked up a parts car and put the drivetrain feom that in to my car.
Right now the car runs and drives. But needs a tune and a couple minor things.
Mods now
scm61
850cc injectors
Safc
Wideband
New short route intercooler
Ghetto 3 intake
2g maf
Evo fuel pump
Xtd 4 puck unsprung clutch
Ebay 38mm wastegate
I plan on upgrading to a 255hp fuel pump and get a eprom ecu and have shane tune it.
Old 05-09-2011   #2
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
Re: Beater 1g
your gonna need a new clutch soon too trust me... ill show you some pictures of my xtd 6puck unsprung after 500miles other than that looks like a fun project good luck and have fun with it!!
Originally Posted by 311evo
Old 05-09-2011   #3
93gtpeater
Re: Beater 1g
Iam not worried about the clutch. I have ran lots of xtd clutches and never had a problem. And the way I will drive it tranny will be smoked in no time.
Old 05-10-2011   #4
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: Beater 1g
I use a stage 2 XTD Pressure plate and an ACT unsprung 6 puck disc and have been more than happy. 24psi on an e316g, pavement donuts and 2nd gear double clutches don't even phase it.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 05-10-2011   #5
Re: Beater 1g
Sweet! Where's pics of this beast?
Old 05-10-2011   #6
93gtpeater
Re: Beater 1g
I will try to get picks up tonight.
Old 05-10-2011   #7
93gtpeater
Re: Beater 1g
Old 05-10-2011   #8
Re: Beater 1g
bigger pics plz haha
Old 05-10-2011   #9
19TsiAwd90
19TsiAwd90's Avatar
Re: Beater 1g
Only issue I had with my XTD was the rivets sheared off from the center hub to the outer hub.. The pressuer plate I'm still using and love it with my clutch net sprung 6 puck
Old 05-10-2011   #10
93gtpeater
Re: Beater 1g
I couldnt figure out how to make them bigger.
Old 05-11-2011   #11
Re: Beater 1g
post the link to your photobucket profile and I can post bigger pics then
Old 05-15-2011   #12
93gtpeater
Re: Beater 1g
Well I took the car out today after I installed some 680 injectors. Runs and drives great. Running about 24 psi of boost. A/f is stay around in the 11.5 range. Just need to find a e85 gas station near by and top off. Car pulls pretty hard for what it is. Looking to upgrade the fuel pump and head studs next. Mabe some cams if I can find some used ones. And put my fic 850cc injectors and turn the boost up more. Proably get a eprom ecu and have it tuned. Just glad I got this thing back on the road for once.
Old 05-15-2011   #13
Re: Beater 1g
Nice! Running driving cars > 1 year projects. Guess I should have listened to my own advice LOL
Are 850's enough for the scm61?
Old 05-15-2011   #14
93gtpeater
Re: Beater 1g
Proably not if If I do cams and headstuds. If I want to max my set up out I will have to go bigger injectors. I bought 850s think they would be big enough for what I wanted.
Old 05-25-2011   #15
93gtpeater
Re: Beater 1g
Little update picked up a eprom ecu and a 255 lph fuel pump. I think the pump thats in the car is maxed cause it starts to lean out up top. This weekend I plan on putting the new pump in and swwing if that solves my problem.
Old 05-28-2011   #16
93gtpeater
Re: Beater 1g
Installed my walbro 255 pump today. Took the car out this morning and it rips all the way to redline. I plan on saving up some money and bring it to db and have shane tune it with the 850s.
Old 05-28-2011   #17
Re: Beater 1g
Like.
Old 06-04-2011   #18
mike55112
mike55112's Avatar
Drives: 04 evo
Re: Beater 1g
Pretty sure I saw you on 35w tonight doing a pull. If so, your car looked like it pulled pretty hard.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 06-04-2011   #19
93gtpeater
Re: Beater 1g
Yeah that was me. Raced a c6 making 475 at map and got walk. goes pretty for being untuned. You should of came to holiday
Old 06-04-2011   #20
mike55112
mike55112's Avatar
Drives: 04 evo
Re: Beater 1g
I would have but I had to drop the girlfriend off at home and then went home. You going out tonight?
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
