Old 05-21-2011   #1
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Bad CAS
I replaced the spark plugs only and it sounded like it had 272s. I turned it off and turned it back on and it idled fine. Once it warmed up, it started to not idle very well. Giving it a rev to 2k, it started stuttering and sounded like a consistent misfire. While warming up, it didn't want to stay on idle and sometimes it just dies immediately. CEL is on but I have no clue of how to check it. This happened when I switched from Link to my OLD ecu chip, the technomotive chip, just to see if it'd be fixed but it wasn't I forgot to record the code when I took out Link but IIRC it was something with the crankshaft 'something something' sensor.
But, even in Link, it was having the same issues. When Link was in, I NEVER brought it into boost. All I did in Link was set Dead Time and Global fuel to the correct values and zero'd everything else. The mas was automatically corrected. I'm just a bit scared that it might have skipped timing a bit but confused on how it did it when it's never been in boost and it's only seen vacuum.
So, I'm just hoping it's the CAS and not anything big.
cliff notes
- idles fine until warm-up
- not keeping idle. after warm-up, car dies.
- free-revving to 2k, it sounds like a consistent misfire
- replaced spark plugs and still the same issue.
- took Link out and replaced it with old chip, same issue.
ლ(ಠ益ಠლ)
