Old 06-02-2011   #1
93gtpeater
Drives: cbr 1000rr repsol
Injectors what ones work the best
I was planning on having my car tuned with my fic 850s on e85. But some things have come up with the car. Needs timing belt. So when I do that iam doing head studs and cams. I would like to buy new injectors that will get me to my goal. Which is 400 to 450 hp at db. I know I need some injectors in the 1000cc or bigger. But ones work the best? And what size to get. I plan on doing a eprom chip.
Old 06-02-2011   #2
311evo
311evo's Avatar
Re: Injectors what ones work the best
I like FIC injectors, for that power You'll prolly want like.. 1250's? maybe smaller.
Old 06-02-2011   #3
mlomker
*Resting In Peace*
mlomker's Avatar
1000cc was good to 410@DB on my car, so I'd say 1250.
Old 06-02-2011   #4
Depends on how much fuel pump you have behind it. FIC 1050's might be enough with a modded walbro or maybe with a BAP. I think 1250's would be safe but again, make sure you have enough fuel pump. A rewired and modded walbro would prolly be plenty.
Old 06-02-2011   #5
93gtpeater
Iam running a 255 walbro rewired right now. I was wondering what would be the beat brand. I was looking at some pte 1200s. I just dont dont buy injectors that suck. Cause I heard the bluemax 1350s suck to tune.
Old 06-02-2011   #6
You should do some research then because IIRC PTE1200's are junk and not to be used on e85. Search on here by posts made by ecoli about that. Matter of fact, a good person to talk to would probably be him, (shane @ DB Performance).
I recently installed a set of FIC1680's in my evoX and they're probably the best idling, smoothest 1600cc injector out there but....you pay for it! Again, might wanna check and see what others are using on their dsms with the same tuning software.
Old 06-03-2011   #7
haha, read back a few posts of mine in a similar thread. I pretty much said the complete opposite. My 1350's are fine, Shane didn't have any issues while tuning with them as far as I know (He didn't say anything anyways). The PTE 1200's have had a bunch of failures when using E85 I guess. Word is they are not compatible with E85, some have used them and not had problems (1QUICK4 used them I know), some have installed them and had a dead injector straight out of the box (or so I'm told). I would stay away from them.
EDIT: found it
http://mitsustyle.com/forums/showpos...5&postcount=29
Old 06-03-2011   #8
93gtpeater
Thanks goodhart. I guess I will go with some fic 1350s then.
Old 06-03-2011   #9
Speedfreak
Drives: four tires
FYI, I had sent my pte 1200's in due to one or more not funtioning properly. At that time I asked about e85 issues with the 1200's.. they claim they have never had an issue with e85 and any of their injectors. Who knows, but after apparently misplacing mine, I got a different bodied 1200 from them in the mail. They claimed they are what I sent them, I don't think so. In any case, put the new ones in the car to see what happens and it started right up.
