Old 06-08-2011   #1
maperformance
Drives: EVO
Send a message via AIM to maperformance
Look at me!! Evo X catback exhaust System w/ Varex Muffler
This full 3″ exhaust system features a single 4″ diameter tip for a subtle look that exits on the passenger side. It is constructed entirely of 304 stainless steel for ultimate durability. It also features a v-band disconnect for easy installation and removal, and includes all necessary hardware and gaskets.
The Varex Muffler
VAREX mufflers combine both the design technology of the stock muffler and the performance muffler into one single compact unit. A sophisticated butterflyvalve mechanism is implemented to redirect the exhaust gas flow and vary be-tween the two.
For higher sound level, the exhaust flows are directed through the opening path and produces maximum power with a robust sound level (or the “sports car note”) and near-zero resistance. Whilst for lower sound level, the exhaust flows are directed through the chambered path (similar design with the stock muffler), and produces minimum sound level that gives you the best in-car comfort.
Angle of the valve is also controllable, which can be adjusted to stop at any point between sports mode and silence mode. This gives you further freedom to set the optimal sound level according to your desired preference.
Settings
Street Mode
Setting your Varex muffler in ‘Street mode’ enables lower sound levels and maximum discretion, as exhaust gases are directed through a chambered path as would a ‘stock’ muffler
Race Mode
For greater power output and sound level, exhaust gases are directed through the opening path and produce maximum power with a robust sound level (or the ‘sports car’ note) and near-zero resistance.
“Anywhere in between”
As the angle of the valve is infinitely adjustable, it can be adjusted to stop at any point between sports mode and silence mode. This gives you further freedom to set the optimal sound level according to your desired preference.
For more info on these items and more click here!
maperformance is offline   Reply With Quote
