Old 06-26-2011   #1
MAP Proving Grounds 2011 - Results, Pics, Videos, and Stories!
Holy shit what a weekend! I have like 15G of HD video, a ton of pics, and countless stories!
Thanks MAP for an amazing time.
It's a crazy story, but I beat out tachyon in the final for Stock Appearing. I'm still in shock!
Old 06-26-2011   #2
Re: MAP Proving Grounds 2011 - Results, Pics, Videos, and Stories!
Figure I'll repost this for Mark:
Originally Posted by Mark Leasure View Post
Only made one pass had a BOV weld/material fatigue issue. More than likely due to my welding, did this like 6+ years ago.
Lost some boost to a leak, assuming this started to crack in 3rd gear. Then at the 8K mark in 4th gear it let go. It was still was a great run. The launch was a 1.61 60 foot. I was very happy!
http://www.youtube.com/watch?v=p5qpC65rnfg&hd=1
Old 06-26-2011   #3
Tachyon
Tachyon's Avatar
Drives: Icarus
That was an awesome time. I tip my hat to you for your victory, couldn't have gone to a more classy stand-up guy
http://www.youtube.com/watch?v=a3ViNWVBwm8&hd=1
I'll get you next time.... gadget.
-Sebastian Vettel
Old 06-26-2011   #4
cmspaz
Walls need hugs too
cmspaz's Avatar
Wewt.
Long story short, the car has high 11s in it and I wasn't getting out of first and second early enough, but after that pass I called it quits. I habitually put the car in neutral and pump the clutch a few times after each pass as I'm braking, and that time the pedal was super squishy and only returned about halfway for two pumps, a third one and it was fine. No slipping on the pass obviously, and none on the quick pull in the return lane, but it was disconcerting enough to end my day. I've been suspicious of my master cylinder for quite some time now, and this close to solidifies it. The engagement point didn't change all weekend, and I doubt heat would have caused an issue that short-lived or intermittent.
I'm waiting on Scheides' GoPro vids!
Originally Posted by Trogdor
Old 06-26-2011   #5
cmspaz
Walls need hugs too
cmspaz's Avatar
Also, Saturday's autox results: http://www.cwscc.com/results/2011/BIR/birfin.html
Myself, 4th in RAW times, 11th in PAX, 1st in class. On tires that weren't meant for it.
Old 06-26-2011   #6
http://www.youtube.com/watch?v=W52TKaPn684&hd=1
Moar to follow. I just have to upload some more videos. Wish I could have been there yesterday, but it was my 1st wedding anniversary. Sounds like there was much more action Saturday. Maybe next year
Announcer was again HORRIBLE. Just murdered everyone's names (As you can hear in the video LOL), and someone needs to tell him how to pronounce Mit-su-bishi and not Mitchy-bitchy.
Old 06-26-2011   #7
Thanks man! Racing is fun when its between friends!
So I won the Stock Appearing class for drag. I don't know how I did it. Saturday morning was insanely fun out on the AutoX course--I suck at wheel turning but I had a fantastic time doing it--this course was one of the fastest and most satisfying I've been on! I will be reviewing logs but if you look at some of the videos (I'll post later) 70+mph is achieved at the finish line. I'm having a weird issue with par throttle in the 2500-3000rpm range where my car wants to fall on its face. I wanted to have it resolved by this weekend but ran out of time and said fook it--add to that the fact that I'm a newb and I will yield very average times, blah!
But it was fun as hell bringing sleepydsm, Mike S, Paul, and others over for their first time through an autoX--you guys don't know how spoiled you were though by not having to work corners! These guys showed up and beat my ass, I was pissed!
On to drag racing. My goals were 11.99@120mph, should be obtainable. Saturday afternoon was just abysmal for me. I tried all kinds of different combos of tire pressure and 2-step rpm to no avail. My car was performing very inconsistent off the line--I'd either bog REALLY bad or I would swear the clutch was slipping. At first I thought I had left my foot on the clutch pedal and caused this, but after a few passes with a best of 12.7@120mph I ran a pass and the clutch slipped in EVERY gear under power. I got back to the campsite and nearly lit fire to the thing, I simply could not believe it! The PP has like maybe 7k miles on it and I replaced the disk 5k miles ago when the motor was out; only a few launches from autoX earlier in the day on it.
After pouting for a while and watching others rip some great times, I was walking back to the campsite with Spaz and he goes, 'clutch fork stopper!' and immediately I picked up my pace. Got back and sure enough, the fork was literally smashed against the fork stopper--GAH! Removed fork stopper and went for a short rip, no slippage!
Sunday came. I was dirty as shit and sooooo fukin hungover. 6500rpm 2-step and 28psi in the tires. Bogged off the line but clutch held great. 12.99@123mph. Woot for more mph, bleeeh for a weak time. I come back around, try again, semi bog again, 12.3@122mph. Up the 2-step to 7000 (where I had it last fall at RF) and go back out, car spins and I get excited for real wheelspin launch and grab 2nd way early, bog it a bit, then rip the rest of the track. 12.3@122 like before but I am finding my groove!
Back in the campground I'm with Shawn(DoughtCom) and we make plans to dominate by dividing...lower tire pressure to 23 all around in hopes of a bit more grip but not too much. Of course Shawn and I get paired up....we bet $1 and I end up beating him, but at the end of the track in 4th gear my car is sputtering as it hits 8000rpm like its out of gas...but its an X, it has 1/4 tank still and that's apparently too low! I get my timeslip: 11.8@117mph. WOOT! Got my groove on now! Find Mara (Shane@DB Performance's wife) and ask about a bunch of e85 they had....throw in 5 gallons to be sure.
Get back inline and they pit me against Bryce. He is intense but I show him how intense I can be with another $1 bet, cause I'm racin' for serious! We line up, it is the freaking closest race ever--he pulls a bit in 2nd, I reel him in in 3rd, then dead even through the finish and it is freaking CLOSE I mean we are literally mirror-to-mirror at the finish! We get the slip and I think I beat him by like .05 seconds. Great race! 11.6@121mph--I flip out! This is huge and about as perfect as I'll get for today I think! I am beaming!
I pull around and there's tachyon in his 1G and this guy in a 335i left....and me. They tell me I get a bye and I'm thinking 'for what?' and realize that I'm somehow in the final. Holy eff! So Paul beats his ass and then he and I line up. It was closer than I thought but I edged him out with a 12.1@120mph.
So yea, beaterX takes the Stock Appearing class with me at the wheel, I am proud!
Full size for detail: http://www.scheides.com/gallery/evoX/IMG_0029?full=1
Thanks again to MAP for putting this event on and the sweet shortblock in my car (amongst other parts!), it has performed flawlessly.
Thanks to Shane@DB Performance for the awesome tune, endless great advice, and for telling me he was sure I would have been on nobody's list of people expected to win that class! Seriously though THANK YOU for helping me win this.
Mark Leasure, Jim Hayek(TalonEvo), Spaz, thx for helping me with my shitty driving this weekend. Spaz beat me first thing sunday morning (I have great video of his car going all the way down the track right in front of me) so I had to show him up
Thanks to everyone else who has ever helped me on this thing, I had an absolute blast this weekend and even with issues the car performed like a champ.
All above commentary subject to being revoked or changed, I haven't reviewed logs yet from today, if I find anything wrong I will totally go back and ricer-math my times/mph's
I'll post the vids later, GoPro footage is amazing.
Old 06-26-2011   #8
I can't believe I only hit 1 cone in all those runs! My times are lackluster though, need to get cloooooser!
Old 06-26-2011   #9
Yes the Gopro of my 9.4 is what I am wanting to see. Thanks for all the help guys and keeping me at the track, it was a blast.
Old 06-26-2011   #10
Dizmm
Dizmm's Avatar
Drives: on ICE
I had an awesome time. Road course filled up completely plus some, auto-x had a decent turnout, and we flew right through the runs getting 15 runs on saturday and 10 runs today.
thanks to those that came out and tried an event where you had to turn the steering wheel!
Andy Smedegard
Dizmm is offline   Reply With Quote
Old 06-27-2011   #11
mike55112
mike55112's Avatar
Drives: 04 evo
I had a great weekend, the autox course was so fun and being my first time I think I did pretty well. I placed second with a time of 34.154 right behind spaz with his time of 33.628.
Drag racing was alright for me this time around, I ran a 12.7 at best. I was pounding through the gears shifting out of 1-3 at 6k and running 4th all the way out. I'm gonna go back after I put my IX turbo in to see if I can get a taste of 11's. I was getting mostly 1.7-1.9 60 fts.
The drinking was really fun, I had a pretty good time with jim and kevin late saturday night driving shane and mara back to their hotel. Jim was telling kevin to just pound through the gears all the way back to the track. Damn jims car feels fast.
I guess I was supposed to get a trophy for the auto x but never picked it up, any chance anyone knows who I would contact to get it?
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 06-27-2011   #12
Sparky2211
Sparky2211's Avatar
Drives: 2g DSM, 2008 Evo X
I was only up there for Saturday, but I had an absolute blast!
1997 Eclipse GSX - Project car - 601hp/475tq
2008 Evo X GSR SSS - Daily Driver - 407hp/434tq
Sparky2211 is offline   Reply With Quote
Old 06-27-2011   #13
Dizmm
Dizmm's Avatar
Drives: on ICE
I'll PM ya. (i was running the Auto-X event)
Andy Smedegard
Old 06-27-2011   #14
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Wow, great jobs guys! Scheides did you put a heat shield over your mani? Curious how ya managed stock appearing
Old 06-27-2011   #15
Yessir, quite proud of my fabrication skills on this one! I really like having the extra heat shielding back there to be honest, think I might just leave it on there!
Old 06-27-2011   #16
I was quite impressed with your car man! Too bad you can't run slicks all day every day, right?
Originally Posted by At-Least-It's-An-Evo View Post
The best I could do with FWD (right side of the slip)
Funny thing is my 1g trapped exactly 132.90 7 yrs ago too... weird.
Thought I see you go down the track with street tires on sunday....how much worse was it?
Old 06-27-2011   #17
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Hahaha. I did do one run "just to see how it is" and it was hilarious. Worse than the street, I kept letting off and hitting the brakes. 14.8 at 98 mph or something because I was laughing the whole way.
2.3 60 ft and all.
'04 Honda Ricer: stock
Old 06-27-2011   #18
cmspaz
Walls need hugs too
cmspaz's Avatar
Hit me up too for mine.
Old 06-27-2011   #19
Tachyon
Tachyon's Avatar
Drives: Icarus
I ran a personal best on Saturday of 11.7 @ 118. My 60 foots were demoralizing terrible however. If I tried a normal street launch it would bog, if I did even 500 more RPM, my 4 year old rocks would just get torched. It's amazing how much a drag track can expose flaws in one's launching technique.
-Sebastian Vettel
Old 06-27-2011   #20
cmspaz
Walls need hugs too
cmspaz's Avatar
^ or make it shine, in some cases.
