Old 07-23-2011   #1
turboDSM
turboDSM's Avatar
Drives: tastefully modded BMW : )
FS?FT Built BMW E36 328is
looking to sell and or trade my built 1996 328is. car has 208k for miles. would like to trade for an EVO of some kind.(have cash to put on top of my car.) depending on trade ill include the bbs's..Outright price of $6,500 with stock 16" sport wheels with winter tires.
Build list
MOTOR: dynode at 225hp/194ft at the wheels.(have dyno sheet)
• S52 cams, out of a 99’ M3.
• M50 intake manifold.
• Riot racing 68mm big bore throttle body
• Turnermotorsport underdrive pulleys
• Dinan carbonfiber intake w/ k&n
• Bavarian autosport power programmer.
• Traction control delete using bimmerworld silicone throttle body boot. Wired in a 10ohm 1 watt resistor so the ABS light won’t come on.
• Clutch fan removed. 80c thermostat, 80/88c fan switch, and two bottles of Red Line Water Wetter. All a kit from bimmerworld
• VSL aluminum Radiator W/ blue Samco hoses
• EMP/Stewart High Performance Water Pump
• BMP racing oil cap
EXHAUST:
• Active Autowerke track pipe.
• B&B tri-flow catback
DRIVETRAIN/BRAKES:
• ZF trans
• Limited slip diff (3.23)
• Lightweight Flywheel
• Sachs clutch and pressure plate
• OE rotors with hawk pads.
• B&M short throw
Wheels/tires:
• 18x8, 18x9 style 5’s. Fully polished barrels and gold BBS RS bolts.
• 215/40r18 Hankook Ventus V12 Evo K110 extra loadbearing side walls
• 235/40r18 Hankook Ventus V12 Evo K110 extra loadbearing side walls
• 82mm Bulletnose Wheel Stud kit
• Turner motorsport black lug nuts.
SUSPENSION:
• KW V1 coil-overs
• turner motorsport sway bar kit ( 30mm,24mm)
• Strut-tower bars. Painted car color.
• X-brace
• M3 rear subframe reinforcement plates
• powerflex rear subfame bushings and RTABs
BODY:
• New in box DDM M3 front bumper. With OE detachable front lip. w/ velocity splitters. (needs paint still)
• DDM M3 side molding, with BMW motorsport international emblem.
• Seibon carbon hood
• M3 rear diffuser.
• 20ish % tint
• Brake cooling ducts
• Rolled front and rear fenders.
LIGHTING:
• DDM clear corner lights. With stealth bulbs.
• DDM clear side markers.
• DDM euro tails. Red/clear
• DDM apexcone 8000k HID projectors.
INTERIOR:
• Bavarian autosport plush floor mats
• ZHP shift knob
• Kenwood deck.
• M3 Vader interior
*also have a bunch of stock stuff going with it. set of crystal fogs. (fogs are wired for HID's)*
BBS's http://eurowerks.org/showthread.php?t=33987
turboDSM is offline   Reply With Quote
