Old 08-22-2011   #1
Swanny
Swanny's Avatar
Drives: 2G Talon
Engine Rod knock only during boost? Bad Turbo?
Im so puzzled. IDK if I have a cracked exhaust wheel or a bad knock only at boost, or a leak...
Just started a week ago under the same conditions, I have this chirping noise, weird noise coming ONLY from the driver side ONLY during 10psi +
I ran the car to 5k rpms with no boost....no engine noise.
I ran the car too 5k rpms with 10psi+ boost and the noise is there.
When the car is running to temp. the noise happens ONLY. Not when cold or slightly warm.
Turbo is 16G, Unknown/authentic? shaved compressor housing, 450cc injectors and stock fuel system @15psi, 3g lifters, 10w40
I do have belt noise that sounds like a rattling heat shield noticeable at low rpms
things to check.
shaft play/ turbo f-ups?
Fix leak between downpipe, 02 housing today, still nothings changed from a week ago
boost leak test
I will Upload a video of the noise tonight... I dont care what the problem is, just hope its not the brand new 6 bolt motor!!!!
Swanny is offline   Reply With Quote
Old 08-22-2011   #2
311evo
311evo's Avatar
Re: Engine Rod knock only during boost? Bad Turbo?
Have you checked the shaft play yet? I would do that right away. You don't want any shavings from the turbo making it down into your oil pan.
It shouldn't be rod knock. If it was rod knock it would knock in or out of boost at X rpm.
Old 08-22-2011   #3
Swanny
Swanny's Avatar
Drives: 2G Talon
Thanks,
Shaft Play is the first thing I'm checking this evening!
Turbo seems to keep the same performance during this noise
Will Update progress soon
Old 08-25-2011   #4
Swanny
Swanny's Avatar
Drives: 2G Talon
The turbo is still in great condition.... hmmm..
The rattling i believe to have fixed it now that I ripped of the stock downpipe heatshield (waiting on aftermarket downpipe)
Fixed exhaust leak.
Re-sealed the J-pipe with RTV, waiting to dry till tomorrow and see if anything has changed.
Waiting on air compressor
Still looking for ideas...will get video up if this doesn't fix it
I will keep ya'll updated
Old 08-26-2011   #5
Swanny
Swanny's Avatar
Drives: 2G Talon
was a leaky j pipe lol almost put it away for the winter
