Old 10-18-2011   #1
Dizmm
Dizmm's Avatar
Drives: on ICE
FS: 93 EG Civic Hatch, H22 Swap, Road-Race Built.
This was a fun little car, but i can only have so many cars at once due to garage space. I want to see if anyone is interested in the car as a complete package.
This car is setup very well. Take it to the big track, auto-x's, or use it for wheel-to-wheel, it won’t disappoint. Feel free to ask any questions you may have!
Car has been carefully gone through, many many things have been replaced. Not all are listed, but most all of the bigger items are. Everything on the car is well documented, and will go with the car. Car can be driven on the street, however there is no place to put your morning coffee so that’s kind of a bummer. Also car is an ugly yellow (in case you didn’t notice). I planned on spraying it another color, but haven’t had time. About $70 in spray cans could do the trick. Nonetheless, scroll down...
1993 Honda Civic CX Hatch Race Car
Engine:
H22a Engine (had 40k on when installed, total of maybe 50k miles on it) - $2325
Arizona Race & Machine P72 ECU, Mugen Spec Chip - $361.35
Jackson Racing VAFC - $55.09
Hasport Mounts - $529.99
“Stage II” Cylinder Head, - Total $1120.40
-Titanium Springs & Retainers
-Brand new OEM Valves
-Lightweight Cam Gears
DC Sport 4-2-1 Header - $356.95
Fluidyne Aluminum Radiator -$356.95
FAL Electric Fan - $179.95
Thermal R&D Cat-Back Exhaust - $532.00
Cheap Cold Air Intake
Drivetrain:
I am told it’s the tranny from the non-Vtec Prelude. Its geared high, 3rd does about 100mph.
Just freshened up the trans, New 5th Sleeve Set, new Synchromax fluid – Parts Only: $230.99
ACT Race Clutch, w/Hybrid Street Disc - $434
ACT Pro-Lite Flywheel - $265
Drive Shaft Shop Axles - $338.43
Turning Mods:
Skunk2 Pro Race Coilovers - $850
FULL Energy Suspension bushings throughout. - $199.95
Progress Group Front/Rear Sway Bars - $
Skunk2 Camber adjustable front/rear Control arms - $239
Progress Camber/Caser kit (used for added caster)
Custom tuned/Corner-weighted/Aligned, All Documented.
Aero 13x8 Race Rims on Avon 9in Slicks (60% life left) - $503.38
15x7 MB Drifter GBM Rims on Dunlop Sport DZ101 Tires(95% left) - $538.12
Brakes:
New Blank Rotors
Hawk HP+ Pads
ATE Super Blue Fluid
Chassis and Misc Mods:
Competition Engineering 8-Point Roll Bar, Welded in.
Corbeau Forza Race Seats w/ Corbeau mounting brackets/Sliders
Autometer Tach, Water Temp, Boost (for when you boost it) w/Pod – $530.54
Crow Driver & Passenger 5pt Harnesses
Other New Parts:
Both Headlights
OEM Honda Wire Harness
OEM Honda O2 Sensors - $308.76
OEM Honda Shifter Assembly - $160
OEM Honda 92-96 Prelude Throttle Body - $185
OEM Honda Front Lower Control arms - $237.91
OEM Honda Half Shaft Assembly - $186.02
Plus TONS of other little parts. I only listed some of the bigger items. See pics of receipts.
Few Spare Parts:
H22 Vtec Transmission, Fully working
17x7in Rims, no tires
Spare Axles
2 spare Avon Race slicks
Spare OEM Control arms
Spare front rotors and pads
Some pics:
$5k for the entire package.
Andy Smedegard
Dizmm is offline   Reply With Quote
