Old 10-18-2011   #1
Turbo for DSM, that makes full boost from 4000-8500+RPMS?
Can anyone find one, between years of experience, professionals, and you professional Introwebz users can anyone find me a turbo that will do as I have asked in the title.
I can accept a late start like 4500rpm and maybe a max of 8000rpms if the turbo comes up on early.
We will call full boost - 25-30psi.
Motor is a 2.3, cams will be GSC S2 grind for strokers.
Plan is to do a 2.3 to 2.4 limit revs to 8500 - 9k. The power doesn't really matter that much because most things that will flow in that region will most likely flow 550+, if i had to state a number I'd say 600 at map thru a 5 spd.
I'm more worried about the RPM as I'm limited to 3rd gear at the track.
Now, i know I should probably just get a X, because I have seen scheides to do it. Please end that talk here, also get MN to use sand instead because I couldn't drive that car in salt i would cry. (well not everyday)
I found this:
2.3, HTA3586 .82, FP3 cams.
