Old 11-16-2011   #1
input shaft and pressure plate height question
Hey, I want to know how difficult it'd be to adapt a DSM clutch to a conquest flywheel and trans. So, with either uninstalled or installed pressure plate height (at the fingers where the throw out bearing touches) if anyone knows that measurement would you please tell me? And also the number of splines and size of the input shaft of the transmission would be good info. Those are the main things I can think of. I can get new holes drilled in the flywheel and the contact surface sized right with fidanza inserts I think.
btw, when I say PP height, that's laying on a flat surface or mounted to the flywheel with clutch installed measured from the flywheel/equivalent surface.
