Old 03-25-2012   #1
KROME
KROME's Avatar
Drives: Black 95 gs
New to the Mitsu Scene
Hey guys, I moved up here from the Milwaukee area last fall for school. I'm fresh to Mitsubishi. Used to be a Nissan guy. Been havin some problems with my car so I figured this would be a good place to ask for help.
KROME is offline   Reply With Quote
Old 03-25-2012   #2
Trogdor
Trogdor's Avatar
Drives: people crazy
Re: New to the Mitsu Scene
Welcome. Lets see some pics!
Trogdor is offline   Reply With Quote
Old 03-25-2012   #3
viridionplague
needs more info and pics! otherwise welcome!
Old 03-25-2012   #4
Tachyon
Tachyon's Avatar
Drives: Icarus
Welcome.
Here's all you need to know about Mitsubishi:
Step 1: Buy Evo.
Step 2: ???
Step 3: Profit.
-Sebastian Vettel
Old 03-25-2012   #5
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
^ what? I don't get it?
Looks like you own a GS. Not a ton of non-turbos on this sight but alot of knowledgeable people that's for sure! Welcome
Old 03-25-2012   #6
KROME
KROME's Avatar
Drives: Black 95 gs
Thanks for the welcome guys. Got my album started.
Old 03-25-2012   #7
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Welcome, and if you want to turbo it (your non-turbo) Jungy is your go to guy on here.
What issues are you having? Those 420a's are unstoppable, well until the water pump goes out. Otherwise, rock solid.
Old 03-25-2012   #8
KROME
KROME's Avatar
Drives: Black 95 gs
I wish I could turbo it. Need another job first. When I first got it, rear main seal went out. I had that fixed but now there is a slow drip at the back of the engine from a brass plug that I don't think is supposed to be there.
NOW, I need an alignment but the hardware on the control arms are seized up. All shops said they wouldn't touch it.
Old 03-25-2012   #9
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
welcome fella
2006 WW IX RS 396/404 - SOLD
Old 03-25-2012   #10
Welcome! Grab some PB Blaster and soak everything down, like 3 times over a weeks period. Then try and loosen things, if they aren't going decent, then throw some heat at it with a torch.
Old 03-25-2012   #11
cmspaz
Walls need hugs too
cmspaz's Avatar
Or just do what I did on my old 2G and cut most of the old suspension stuff off the car and replace it with all new stuff.
Originally Posted by Trogdor
Old 03-26-2012   #12
welcome
Old 03-26-2012   #13
Welcome!
Old 03-27-2012   #14
KROME
KROME's Avatar
Drives: Black 95 gs
I talked to some mechanics and they said that I'll have to cut through the bushing and the sleeve to get it all apart. Fun :P
Old 03-27-2012   #15
Are you talking about the A-arm?
Old 03-28-2012   #16
cmspaz
Walls need hugs too
cmspaz's Avatar
Just borrow an angle grinder and go to town. Should take 3 wheels or so to get through the arm, bushing, sleeve, and bolt. As I said, been there, done it.
Old 03-28-2012   #17
KROME
KROME's Avatar
Drives: Black 95 gs
You've dealt with this before? And you could get an angle grinder in there? The mechanics that I talked to said that I wouldn't be able to get one in there. On the other forums they said a sawzall would be needed with a bunch of blades.
Any tips or advice would be much appreciated.
Old 03-28-2012   #18
tehehodi
Braaaaaaaap!
tehehodi's Avatar
We've all been there. I don't remember how I did it on my friend's GS but I did. Get a sawzall and go to town. Cut wherever necessary.
Old 03-28-2012   #19
KROME
KROME's Avatar
Drives: Black 95 gs
Ugh. This sounds like way too much fun. Thanks guys.
