Old 04-09-2012   #1
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Rims/Rods/Block/ PARTS LOOK!!!
Not building a 7 bolt anymore so here it goes...Also need to clean out the garage to much stuff.
Thanks for looking
7 bolt eagle rods w/ARP 2000 bolts SOLD
Eprom ECU $150
96 Auto ECU $50
Eprom chip $25
OZ racing rims 16" w/ ok tires 205/55/16 these rims came on the stock '99 oz edition eclipses (RARE) maybe? $350
6 ARP flywheel bolts SOLD
earl fittings SOLD
7 bolt lower timing cover $30 (no boken tabs/cracks)
7 Bolt upper timing cover $20 (no broken tabs/cracks)
1G BOV $25
2G water pipe $15
(x2) 2G thermo housing $20/each
(x2) turbo gauge cluster 1 has 25245 1 has 143422 $35/$15
(x2) Eagle talon driver airbags $30 each
greddy TT older style SOLD
rear leather back upper seats $40
2G gray triple pillar SOLD
2GB talon highrise wing $100
2GA talon front bumper $30
2GA talon rear bumper $30
2G AWD stock struts and springs $100
2G hood (white) $100 RUST free in good shape
2G hood (white) $75 has some rock chips
2G hood (white) $50 has slight bend up by driver a pillar not bad
2G hood (primered black) $75 Rust free in good shape
2G driver door $50 (no glass minimal rust on the bottom)
2G modded wingless hatch with glass (black) $150
95-96 headlights blacked out housings $50
AWD gas tank $50
2G driveshaft $65
7 BOLT 98+ split thrust bearing needs hone for sure, maybe bore?
Whats included w/ the block
98+ block
oem 7 bolt crank
new timing tensioner
newer oem waterpump
all pulleys
front case
oil pan
pistons and rods
(pretty much everything to put it back together)
$350
oem 7 bolt crank out of a 1g $100
1G 7 bolt bare block $50
If you have any questions please PM me. If you want to buy send a text as this will ad will be on multiple boards.
Text me @ 651-269-2314
Nick
Old 04-11-2012   #2
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Rims/Rods/Block/ PARTS LOOK!!!
PM me best offer! Ill give good deals to those that can pick up parts.
