Old 05-24-2004   #1
H.A.R.T 4G63DSM
Guest
Tournaments Won: 6
Posts: n/a
Very basic question..... I just wanna know if the FPBig28 will directly bolt on to a 2g GSX manifold? Or will you need an install kit? :dsmrule: :goodluck: :dsmrule:
Old 05-24-2004   #2
LightningGSX
Hellbound
It should bolt right up.
-Nulli Secundus-
Old 05-24-2004   #3
bolts right on
Old 05-24-2004   #4
H.A.R.T 4G63DSM
Guest
Tournaments Won: 6
Posts: n/a
Kool thx alot guys for answering my question.
Old 05-24-2004   #5
white 2g awd
Send a message via AIM to white 2g awd
i'm assuming you aren't bolting it up to your 90 dsm right??? if so, just go with a 16g, that one is a direct bolt on, the t28 isn't for the 1gs, you need the 2g water and oil lines.
Dustin
white 2g awd is offline   Reply With Quote
Old 05-24-2004   #6
Enes
Enes's Avatar
if you have a 2g eclipse then yes, the big t28 bolts right in uses same water lines and oil lines..
if you are puting it on a 1g eclipse then you would be better off going with a big 16g or other.
also you might have a 2g manifold which might be confusing you.. they are identical except the runners etc etc... they bolt up identicly so no worries there.
-E
Old 05-27-2004   #7
Also, if you are getting one, make sure it is for a dsm and not a nisan or other car. It will not bolt up if you get the wrong one.
