Old 08-01-2012   #1
clean up sale. 1g,2g,mirage,miata tons of parts
will add more to the list when I go though the shed and the basement shop this week. This is just is what is in the bins in the garage right now still have to go through the rest of the garage and all the 1.8 miata parts.
1g stuff bins garage
1. awd bell housing 30.00
2. awd center case x2 20.00 each
3. awd bearing case 10.00
4. awd end case 15.00
5. 22 spline out put shaft 15.00
6. front awd diff stock 15.00
7. 90 shifter cable bracket x2 10.00 each
8. 91+ shifter cable bracket 10.00
9. 91+ bell housing bolt on shifter arm x2 5.00 each
10.
11. fwd starter plate 10.00
12.
13. oem awd flywheel 30.00
14. front lic. plate bracket 10.00
15. oil pick up tube 5.00
16. 91+ coil pack wiring 5.00
17. p.s. pully on water pump x3 5.00 each
18. alt. pully on water pump x3 5.00 each
19. 193a rear roll stop mount 10.00
20. 195a rear rool stop mount 10.00
21. upper engine block mount x2 10.00 each
22. 4g63 na oil pan 6bolt 30.00 or 50.00 with 10an bung welded on it
23. power mirrors left and right red 10.00 each
24. trunk and gas levers with cables 10.00 set
25. 91+ turbo water pipe 25.00
26. power window regulators and motors left and right 10.00 each
27. blower motor 10.00
28. power steering pump with pully 20.00
29. trunk pop cable 5.00
30. 5 speed speedo sensor x2 5.00 each
31. non radiator cap upper t. stat housing 10.00
32. drivers white door handle 5.00
33. drivers greed door handle 5.00
34. pass red door handle x2 5.00 each
35.
36.
37.
38. awd pass rear calaper w/bracket 15.00
39. 90 cas with wiring no plug 20.00
40.
41.
42. grey hatch cover 40.00
2g stuff bins garage
1. lower radiator metal mounts 10.00 set
2. battery tray 10.00
3. auto upper tranny bracket 10.00
4. auto spacer tin 5.00
5. flex plate stock 5.00
6. front k-member lower bolt on brackets left/right 95-96
7. auto front roll stop bracket 10.00
8. front bumper side metal tins 5.00
9. 95-96 a/c brackets x2 20.00 each
10. knock sensor 25.00
11. stock o2 housing 10.00
12.
13.
14. upper auto tranny mount alum/rubber x2 20.00 each
15. 98 2.4 spyder coil pack 10.00
16. oil pick up tubes x3 5.00 each
17. alt. pully on water pump 5.00
18. fuel rail oem 10.00
19. rear left/right bumper splash gaurds 10.00 set
20. black pass door plastic (switch holder,heat vent ect) 15.00
21. black review mirror with map lights and wiring 20.00
22. upper rear awd left/right control arms 15.00 each
23. black hvac/ raido bez x2 10.00 each
24. 595 tranny bracket 10.00
25. lower t.stat housing (bolts to head) x3 5.00 each
26. compleat t.stat housing 10.00
27. set front wiper arms painted white 15.00 set
28. din pocket under raido 5.00
29. dead peddle 5.00
30. t.b. no sensors and lower block off 5.00
31. t.b. elbo stock 10.00
32. inner tie rod ends w/boots 20.00 set
33. horn stock 5.00
34. bov stock 5.00
35.
36. spyder trunk lift shocks 30.00 set
37. 4g64 dohc ofh non coolant ofh 10.00
38. awd ebake set up w/ cables left/right 25.00 each
39. awd right rear knuckle 95-96 50.00
40. 5 speed upper tranny bracket 10.00
41. auto front roll stop mount bracket x2 10.00 each
42. auto rear roll stop mount bracket 10.00
43.
44. water pipes x2 15.00 each
45. 95/96 overflow bottle 10.00
46. black pass window switch 20.00
47. awd rear left/right brakes w/ brackets,hoses 15.00 each
48. clutch aculmators x2 15.00 each
49. brake peddle 15.00
50. clutch peddle 15.00
51. shifter base no shifter 10.00
52. clutch master w/resavor,bracket 20.00
53. clutch resavor w/bracket 5.00
54. black door handle cover left 10.00
55. black pass mirror trim 5.00
56. power steering pump no pully 20.00
4g63 stuff bins garage
1. lower timming tin 10.00
2.
3.
4. power steering heat sheilds x2 10.00 each
5. rear engine lift mounts x3 5.00 each
6. front engine lift mounts x3 5.00 each
7. alt. arm brackets x6 5.00 each
8. lower fuel pump holder bracket 5.00
9. black cam gear cover 15.00
10. silver cam gear cover 15.00
11. silver cut cam gear covers x2 5.00 each
12. exhaust cams stock x5 15.00 each
13. intake cams stock x5 15.00 each
14. spark plug cover all black 5.00
15. spark plug cover black/silver 5.00
16. rear main seal housings x4 10.00 each
17. crank balance shaft belt pully x3 10.00 each
18. crank timming belt pully x4 25.00 each
19. oil pump timming belt pully x4 20.00 each
20. crank trigger plates x2 5.00 each
21. 7bolt tensinor arms x3 10.00 each
22. 6bolt tensinor arms x2 10.00 each
23. 7bolt oil scraper tin x2 5.00 each
24. oil dip stick tubes x8 5.00 each
25.
mirage/miss stuff bins garage
1. apexi safc mounts ect x2 10.00 each
2. 93-01 mirage raido brackets 10.00 set
3. 89-92 mirage raido brackets 10.00 set
4. evo 8 stock bov 10.00
5. 5g mirage head 1.8 30.00
6. 5g mirage valve cover hot pink 1.8 20.00
7. evo 1-3 power steering set up no pump 50.00
will add more when i go thought all the other parts
can take pics of any of it. some pics are here
http://s122.photobucket.com/albums/o...e/part%20outs/
add 8/2/12 basement shop
all parts are hard top unless marked spyder
2g basement shop bins
1.
2. tranny cooler w/ shroud oem 15.00
3. tan glove box 10.00
4. gst fuel pump sending unit 20.00
5. gst fuel gauge sending unit 15.00
6. rear spyder window glass left/right 30.00 each
7. smic 15.00
8. smic shroud 10.00
9. power window motors and regulators left/right 10.00 each
10. hook latch and cable 10.00
11. window track 2 pieces left/right 10.00 per side
12. lower battery brackt bolts to frame 10.00
13. engine bay fuse box brackets 2 pieces 10.00 set
14. rear wiper motor 10.00
15. front wiper arms left/right black 15.00 set
16. rear wiper arm black 5.00
17. talon main body harness fuse box to tails 40.00
18. power door harness left/right 15.00 each
19. rear wiper/glass heater harness 5.00
20. abs ecu mb921844 5.00
21. ecu mount bracket 5.00
22. control box mb942485 10.00
23. auto comp controller box mb946485 10.00
24. front door speaker pods left/right 5.00 each
25. blower motor 10.00
26. steering colom cover upper/lower grey 10.00 set
27. grey center vents w/ switchs 10.00
28. washer bottle tubes to fill bottle 5.00
29. black gauge bez 10.00
30. grey defrost vents dash 5.00 set
31. grey vents dash to door 5.00 set
32. grey cruse/power mirror switchs w/ panel 10.00
33. red gas door 10.00
34. grey dash speaker covers 10.00 set
35. gas cap 5.00
36. grey map lights w/bracket 10.00
37. black a/c switch 5.00
38. pass o crap handle grey 5.00
39. washer bottle pumps x2 5.00 each
40. grey inner drivers door handle 5.00
41. rear seats belts left/right grey 10.00 per side
42. grey inner door handle cover left/right 5.00 each
43. black door plastics (switch holder,heat vent) panels left right 15.00 each
44. eclipse tail light gaskets left/right x2 sets 5.00 per set
45. grey hvac/raido bez grey 5.00 each
46. tan lower drivers dash 10.00
47. left rear tan spyder speaker cover 10.00
48. rear spyder 6x9 speaker buckets 5.00 each
49. tan home link visors need recover 30.00 set
50. tan pass lower dash panel next to glove box 5.00
51. black defrost vent 5.00
52. stock 5 speed shifter 5.00
53. black fog light switch 5.00
54. front seat belt covers tan spyder left/right 5.00 each
55. black dash speaker grills 10.00 set
56. power mirror black covers x2 right x1 left 5.00 each
57. black right door handle cover inner 5.00
58. spyder top motor 30.00
The rest of the basement shop 8/3/12
59. spyder rear panel metal brackets left/right 5.00 each
60. 97 heater core 25.00
61. spyder rear right window regulator and motor 20.00
62. grey front seat belts left/right 10.00 each
63. grey right kick panel 5.00
64. spyder rear left window track
65.
66. black haz,defrost buttons w/ housing 15.00
67.
68. black ebrake handle 10.00
69. spyder trunk/gas pull handles 10.00
70. spyder trunk cable and latch 10.00
71. hood latch 5.00
72. tan hood latch pull handle 5.00
73. spyder compleat washer bottle set up 15.00
74. black gauge bez 10.00
75. black steering colom covers upper/lower 10.00
76. black dead peddle 5.00
77. tan spyder turnk lever cover 5.00
78. spyder rear window belt moldings left/right 10.00 each
79. spyder trunk seal 15.00
80. inside black door handle cover right 5.00
81. spyder top rear seat flap seal/holder 5.00
82. spyder body door seals left/right 10.00 each side
83. dash board harness x3 10.00
84. spyder top motors x2 30.00 each
85. key less entry ecu x2 15.00 each
86. grey dimmer switch x2 5.00 each
87. spyder top control ecu x2 15.00 each
88. mb543651 contol box 10.00
89. mb942485 x2 control box 10.00 each
90. mb943259 x2 control box 10.00 each
91. spyder door harness left/right 15.00 each
92. 2ga talon head lights 30.00 set
93. abs ecu x2 5.00 each
94. mb903862 control box 10.0
95. black cruise switch on steering wheel 5.00
96. spyder rear window defrost/3rd brake light harness 10.00
97. black wiper switch 10.00
98. antenna wire raido to power antenna 5.00
99.
100. black cruise on/off switch 5.00
101. black spyder top up/down switch 10.00
102. oem cd changer cable 5.00
103. spyder manual top buttons x2 5.00 each
104. new reman upper right control arm front 15.00
105. 5 speed awd front roll stop bracket 10.00
106. wish bones front struts left/right 15.00 each
shed
all parts 2g hard top unless marked 1g or spyder
1. a/c sytem compleat was working when removed from 97 gsx. bracket is 95 150.00 whole or part out
2.
3. head hood 45.00
4. 2ga talon rear bumpers red x2 30.00 each
5. front gst calapers left/right 15.00 each
6. steering coloms w/keys no wheels or switchs 15.00 each
7. grey cloth 95 rear seat 25.00
8. grey door scuff panels left/right 10.00 each
9. tan door scuff panels left/right 10.00 each
10. grey trunk carpet 10.00
11. grey carpet needs good clean 20.00
12. gst front rotors 5.00 each
13. 2ga talon wing no brake light 10.00
14. low ceter wing 10.00
15. tan spyder upper windsheild panel 15.00
16. awd rear subframe (just the frame and lower arms) 75.00
17. grey qt. window panles left/right 10.00 each
18. grey trunk panels left/right 15.00 each
19. awd front oem sway bar w/end links 20.00
20. intake manifolds oem x3 10.00 each
21. intake manifold oem 1g 10.00
22.
23. grey a-pilers left/right 10.00 each
24. grey rear shock covers left/right 5.00 each
25. grey right kick panel 5.00
26.
27. tan spyder right kick panel 5.00
28. grey rear speaker panles left/right 10.00 each
29. north/south awd roll stop bar 25.00
30. upper fender splash sheilds left/right 5.00 each
31.
32. tan spyder rear seat cloth 30.00
33. right front bumper splash sheild x2 10.00 each
miatia parts to go though still
Old 08-01-2012   #2
dragonov_elite
dragonov_elite's Avatar
Drives: 95 Eagle Talon TSI AWD 5spd.
Re: clean up sale. 1g,2g,mirage,miata tons of parts
Which year 7bolt?
dragonov_elite is offline   Reply With Quote
Old 08-01-2012   #3
96
Old 08-02-2012   #4
started to go through the basement shop today add more stuff
Old 08-02-2012   #5
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
stock 14b j pipe and oil drain and feed?
Old 08-02-2012   #6
Nope they went before I started to make the new list
Old 08-02-2012   #7
M1L3S
M1L3S's Avatar
Drives: 99Gst
Do you have lover timing cover ?
Upper timing cover ?
Also o2 sensor
All for 2g 7bolt ?
M1L3S is offline   Reply With Quote
Old 08-02-2012   #8
Just cam gear covers
Have both front and rear o2 sensors
Old 08-03-2012   #9
just added the rest of the basement shop
Old 08-08-2012   #10
went through the shed this mooring add it to the growing list.
sold parts have and will be taken off the list as they go
Old 08-08-2012   #11
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Could you get a pick of that 2gb a/c line? or if you have a 2ga a/c line as well for the low pressure side from the firewall to compressor? (It's the bigger "hole" diameter one)
Old 08-08-2012   #12
sure I have a 2ga one also
Old 08-08-2012   #13
tehehodi
Braaaaaaaap!
tehehodi's Avatar
That would be awesome if you could post both of them. Try to get both ends in the pic, cause I want to know if they are different at the firewall like they are at the compressor or not.
Old 08-08-2012   #14
Ok will get them out. Tomorrow mooring
Old 08-09-2012   #15
mitsukid124
mitsukid124's Avatar
Drives: 97 eclipse gst
1g BOV and 2gb a/c condenser?
mitsukid124 is offline   Reply With Quote
Old 08-10-2012   #16
RS98GSX
RS98GSX's Avatar
Drives: White on White 98 GSX
I have a 2gb ac conbdensor if he doesnt.
RS98GSX is offline   Reply With Quote
Old 08-20-2012   #17
GSTPerformance
GSTPerformance's Avatar
Drives: 97 GST
I need a outer driver side door handle, got one for me? broke my handle yesterday smh
Left foot on the clutch, right foot on the gas, right hand on the gears, left hand on the wheel, cruisin.
GSTPerformance is offline   Reply With Quote
Old 08-21-2012   #18
Is that the center vent part on a 2g?
Old 08-21-2012   #19
Just have 1g outer door handles
It is just the buttons and it's mounting bracket. The black center vent is gone. I do have a grey center vent
Old 08-29-2012   #20
Updated.
