Old 08-23-2012   #1
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
WTB: 2gb sensors
Looking for 2gb 97-99 sensors for cam and crank or whatever it is they run so I can put my plastic ecu into my 96 car.
Old 08-23-2012   #2
Re: WTB: 2gb sensors
I thought the crank sensor was the same, but the cam sensor went on the opposite side, like a 1G. I also though you had to have specific cams with a groove in the end to run the 97-99 cam sensor. Because it's flipped, I believe you also have to switch plug wires and injector firing order.
Old 08-23-2012   #3
tehehodi
Braaaaaaaap!
tehehodi's Avatar
thats what i thought. Thanks andrew
Old 08-24-2012   #4
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Yeah, you do not need to run the specific sensors.
Same goes if you put a 95 ECU in a 97-99. Swap plug wire #1 with #2 and then #3 with #4.
Originally Posted by shoutbox
Old 08-24-2012   #5
If you don't change the sensors, you will also need a ROM with cas inversion or just rewire the injectors at the ECU.
Old 08-24-2012   #6
tehehodi
Braaaaaaaap!
tehehodi's Avatar
I don't think there is a rom with cas inversion yet (Someone correct me if I'm wrong). I thought I needed to do both, switch to the newer CAS AND switch my firing order?
Or do I have the option for either or? From what I've been reading, I need to do both. Again feel free to correct me.
Old 08-26-2012   #7
Wizard
Ecmlink/dsmlink has the cas inversion option.
Wiz
Old 08-26-2012   #8
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Wiz
He's using a 98-99 flash ecu not link.
