Old 09-06-2012   #1
vassil
Been there, done that.
vassil's Avatar
Made 859 whp on my Talon with a PTE 6266
My Talon is finally all put together and I went to the dyno for the second time this year (had oil pump issues a month ago). I was more than pleasantly surprised with the results. Shane Ziegler tuned the car and it put down some serious numbers on DB Performance's dyno. Precisely speaking - 859.8 WHP and 642 ft/lb at 35.2 psi of boost. That was the number in Shootout Mode (Dynojet Guestimate). The actual DynoDynamics numbers were 740.2 WHP and 563 ft/lb. I am super excited about it and it couldn't have happened at a better time, since it was my actual birthday. The essential mods are 2.4 long rod G4CS with Pauter/Ross 9:1 combo, Keflord 276/280, Magnus Cast intake, 2150s, twin walbros, Punishement header, DBB PTE 6266, Garret 4" thick FMIC and DSMLink v3 running speed density. The run was done on straight E98.
A detailed list of every single modification to the car is on my website at: http://www.bulfab.com/Pages/RaceCar.aspx
The car weighs 2660 without me in it, I am around 180-ish. Last year I ran a best of 10.38@142 with a 1.71 60' time (1/8 mile trap was 111). At that time it made 657 WHP and it had a very tired 2.0 in it. It has a Shep stage 4 trans with a GearDrive Quartermaster, but my t-case, rear diff and axles are stock. I hope that if I preload everything and I am nice to it, it can run a 9.9x. Hopefully it all works out.
Big thanks to Jake Vogel for spending countless hours with me in the shop working on the car and Shane for the tuning it.
Here is a video of the dyno pulls:
http://www.youtube.com/watch?v=B6lgDuOipkI&hd=1
Here are some pictures of the car and the dyno sheets:
http://www.bulfab.com/SiteImages/740.jpg
http://www.bulfab.com/SiteImages/859.jpg
Manual 859.8WHP / 642 ft/lbs
10.23@152
Automatic 728WHP / 517 ft/lb
9.85@143
1G DSM Crossmembers
BulFab
Old 09-06-2012   #2
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Made 859 whp on my Talon with a PTE 6266
I'm glad it held together! Hopefully it runs what we expect!
Well worth all the time and hard work! Congrats again man! Awesome "Birthday Present".
Now time to race the bike! haha
Originally Posted by shoutbox
Old 09-06-2012   #3
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Very nice. When are you taking it to the track?
11.35 @ 120mph
Old 09-06-2012   #4
That is fucking badass, good luck to you. Good to see there are still more high power DSMs in MN/local.
*I want that exact setup in my car*
Any reason you chose the long-rod motor? just for safety/peace of mind? They are kind of rare.
Also forgot, happy birthday!
Old 09-06-2012   #5
Tachyon
Tachyon's Avatar
Drives: Icarus
740 AWHP is serious business on Shane's dyno. Very solid.
-Sebastian Vettel
Old 09-06-2012   #6
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Hopefully Saturday we will be at Rockfalls to see what happens.
I'll let him explain the motor situation... But all said and done, I'm glad he went this route.
The car makes crazy power... Shane did the first 3-4 pulls on the dyno just to heat up the tires cause they were spinning at the beginning of the day. Then it was solid from there on out.
We have a local guy that sells E98 for $3.84/gal. He has 250 gallons right now and you can drive your car there and fill up if you really want and he is there every day of the week. Pretty badass when you can get it for cheaper than 93 octane!
Old 09-06-2012   #7
That is crazy awesome power for that turbo! Good luck!
Old 09-06-2012   #8
I think we starting running out of fuel pump and balls to push it more. We didn't totally max the turbo or the octane or run into knock or try to push the tune to the max.
Old 09-06-2012   #9
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Yeah we were pretty conservative with it... I cant believe it just kept making more and more power. I'd rather see it conservative vs being maxed out where one little thing could make the car explode, like a ticking time bomb.
Thanks again Shane for the knowledge and tune! You definitely have the touch!
Old 09-06-2012   #10
Trogdor
Trogdor's Avatar
Drives: people crazy
It is a DSM after all.
Grats, that's awesome!
Trogdor is offline   Reply With Quote
Old 09-06-2012   #11
^ (always someone)
Be careful running more boost a guy on link just had his lockup at 40psi for no apparent reason, PTE came on link and said they suggest 30-35 psi.
Good luck on saturday.
Old 09-06-2012   #12
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
We turned it down from 35 to 32... Made 2 back to back 725whp (DD Numbers) pulls and kept it there. The car was running out of fuel at 35psi and one blip from the pumps and the motor is toast, so we turned it back and called it a day. Better safe than sorry.
Old 09-06-2012   #13
Holy fawk that is some power, and on a 62mm. Very impressive!
By chance, would you expand upon your fuel pump setup? Which pumps (255?), in-tank parallel or some sort of internal/external in-line setup? Use a BAP or anything?
Congrats on the redonk numbers!!!
Old 09-06-2012   #14
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Just twin 255's with the full blown hanger, -10AN feed to the fuel lab inline filter in the engine bay to the rail. 2150 injectors. Nothing all that special.
No BAP either.
Old 09-06-2012   #15
Thanks for that. Good to know twin in-tank 255's can support that much power, on e98 even.
Old 09-06-2012   #16
Freaking crazy power! Good luck at the track, this thing looks just sick!
Old 09-06-2012   #17
mdost03
Sonic Champion!
Drives: VA STI
That thing looks like a beast, congratulations!
Old 09-06-2012   #18
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Very nice!
Good luck on your 9.xx run
Old 09-06-2012   #19
Awesome Vassil! Geez, I wasn't even close to pushing my two Wally's when I had them.
Old 09-06-2012   #20
cmspaz
Walls need hugs too
cmspaz's Avatar
Holy crap, that's awesome! Congrats on the numbers, get that thing to the track ASAP for timeslips!
Originally Posted by Trogdor
