Old 09-23-2012   #1
Speedfreak
Drives: four tires
What's a good price of carpet installed?
I'm looking for carpet for a small bedroom(12x14 approx), but prices seem high. What should I expect to pay?
Any suggestions of places to go, people to use?
Also, was at IKEA the other day, saw some laminate that looked good enough for 1.15sq/ft, any direct experience with this stuff?
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 09-23-2012   #2
1999Gst
Drives: 1999 Eclipse,
Re: What's a good price of carpet installed?
I would PM cornfed2.4 he does that for a living and I'm sure he would probably do it for less than others and better quality.
Old 09-23-2012   #3
Empire actually is pretty decently priced too. Almost went with them until my cousin offered to do my townhouse instead.
Old 09-23-2012   #4
I'd say hit up cornfed on here.
Old 09-23-2012   #5
+3 for cornfed
Old 09-24-2012   #6
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
+7 for cornfed
Originally Posted by shoutbox
Old 09-24-2012   #7
Speedfreak
Drives: four tires
Paging Cornfed.
GSX - 571whp/490wtq
Sienna
Old 09-25-2012   #8
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Here! call me tomorrow. 651-269-2314
I appriciate the +'s guys.
Old 09-25-2012   #9
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
+8
Good luck with your carpet though!
Old 09-26-2012   #10
Speedfreak
Drives: four tires
I'll give you a call in the next day or two. Thanks
GSX - 571whp/490wtq
Sienna
Old 09-26-2012   #11
Do you do stairs?
Old 10-01-2012   #12
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Yeap I do steps.
To speedfreak.
For carpet you could pay $9-$50/yard (average residential $15-18)
Install is from $4-6/yard
Take up is around $1.25/yard
Pad is bought in 30 yard rolls $100-$150 a roll
Carpet and pad price vary since there are different qualitys and styles.
Your bedroom would probably fall in to the minimum carpet charge which can be $125-$175 depending on if you find the labor or the shop you buy the carpet from does.
Carpet on step is a labor charge of $7 a step but also if this is all you have it would fall most likely under min. charge.
The reason for the min. charge is because the shitty mpg we get in our vans and usually only make $75 on a min. charge job.
Speedfreak
Your bedroom is 18yrds
So on average you should pay this
$450-$550 for carpet pad and install
Hope this helps.
Old 10-01-2012   #13
Speedfreak
Drives: four tires
Yeap I do steps.
To speedfreak.
Speedfreak
Hope this helps.
Sounds good, thanks for the info.
I just bought some carpet(will have it later this week). Will need it installed and will need pad.
Once I have it, I'll give you a call.
Do you do tile work as well(your sig says "flooring") or just carpet install's?
GSX - 571whp/490wtq
Sienna
Old 10-01-2012   #14
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Carpet
Laminate
Hardwood
Vinyl
Ceramic/stone (floor/wall)
I do both commercial and residential
Old 02-15-2014   #15
Speedfreak
Drives: four tires
Bumping my own thread. I did buy the carpet I noted earlier in this thread, but I bought it from an auction, took a chance on it being large enough.. and lost. Oh well.
Anyways, I just bought carpet and pad for two bedrooms this size.
CornFed2.4, You free anytime soon? Need this stuff installed.
GSX - 571whp/490wtq
Sienna
Old 02-15-2014   #16
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I have a day open next week. My # is still the same so feel free to give me a call and we can work out the details.
Old 02-16-2014   #17
Speedfreak
Drives: four tires
Sounds good. I'll call you tomorrow.
I have to clear the rooms, any idea what day may be open? Will give me a good idea how much time I have to work with/what pace I have to go tomorrow..
GSX - 571whp/490wtq
Sienna
Old 02-16-2014   #18
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Thursday/friday
Old 02-16-2014   #19
Speedfreak
Drives: four tires
Thursday/friday
Sounds good to me. I'll call tomorrow.
GSX - 571whp/490wtq
Sienna
Old 02-16-2014   #20
Speedfreak
Drives: four tires
Thursday/friday
Just left you a voicemail with basically the same info/questions as below:
If you want to text me your email addy, I can send you a couple sketches with dimensions of the rooms.
Also, if you can give me an idea of cost(based on the actual dimensions I can send) that'd be great.
Thursday or Friday works for me, let me know which day you'd like to this.
GSX - 571whp/490wtq
Sienna
