Old 10-03-2012   #1
4seasons69
4seasons69's Avatar
? About degreeing cams
Ok so my cylinder Head is going to the head head shop this week I'll be running all the same components plus some porting and polishing. so once I get that back the engine will be going back together. Getting to my question. The cams were degreed when the old engine was assembled. Now if the cam gears aren't touched once everything is put back together would the cams need to be degreed again? Any help is appreciated!
Old 10-03-2012   #2
Re: ? About degreeing cams
If the head got milled or you use a different thickness head gasket then they probably need to be checked.
Old 10-03-2012   #3
4seasons69
4seasons69's Avatar
Also can the cams be degreed with the engine in the car?
Old 10-03-2012   #4
4seasons69
4seasons69's Avatar
Well old head is junk. I have a new good core that will be used. So probably should at least be double checked
Old 10-03-2012   #5
If it's a different head, then it needs to be re-degreed.
Old 10-03-2012   #6
4seasons69
4seasons69's Avatar
Awesome! That's what I needed to know. Thanks!
