Old 10-05-2012   #1
KROME
KROME's Avatar
Drives: Black 95 gs
Why does this keep happening?
I recently replaced my power steering pump with an Advance Auto remanufactured pump. I also replaced the belt with their expensive belt.
I just broke my third belt today. Everything seems tight but it keep splitting.
I don't see it rubbing anywhere. I'm lost. Anyone had this problem before?
KROME is offline   Reply With Quote
Old 10-05-2012   #2
Re: Why does this keep happening?
Tension too tight?
Old 10-05-2012   #3
KROME
KROME's Avatar
Drives: Black 95 gs
Tension too tight?
I thought about that but it's pretty good every time. ABout 3/8 " deflection at 20lbs.
Old 10-05-2012   #4
KROME
KROME's Avatar
Drives: Black 95 gs
Could it be an alignment issue? Like the pulleys are out of alignment? Or could pitting on a pulley do this?
Old 10-05-2012   #5
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Well increase engine spead and physically look at the rotation pattern?
Old 10-05-2012   #6
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Yeah, It happend to me before on my 420a, Then I left it off. It's definitely the alignment i'm pretty sure. Do what above person said and see. Otherwise inspect pulleys for sharp edges and what not.
Old 10-05-2012   #7
KROME
KROME's Avatar
Drives: Black 95 gs
When your alignment was off, what was out of alignment? How do you adjust that? Thanks!
Old 10-05-2012   #8
The pulley isn't on backwards, is it? Several of the pulleys are really easy to put on backwards.
Old 10-05-2012   #9
tehehodi
Braaaaaaaap!
tehehodi's Avatar
I don't really remember as it was in HS but i think my pulley was bad. But do what JET said also. Like I said, I also just took off the belt because I got sick of it. Maybe my PS bracket was bent.
Old 10-05-2012   #10
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Did you take off your crank pulley recently by chance?
Old 10-05-2012   #11
KROME
KROME's Avatar
Drives: Black 95 gs
Nope. The guy before me had problems breaking belts and stuff too. I only replaced the power steering pump and put the tensioner in. (It had a bolt in it instead -__-)
I'll look at it tomorrow I guess so I can pull it into the shop and look. Thanks guys. This is so freakin annoying :P
Old 10-05-2012   #12
Check the water pump pulley too, they are easy to put on backwards. You have to take the timing belt cover off for that so it isn't real easy.
Old 10-05-2012   #13
KROME
KROME's Avatar
Drives: Black 95 gs
Ugh. I was afraid of something like that. Thanks though. I'll let you guys know what I find.
Old 10-07-2012   #14
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Edit: Nevermind... wrong engine.
Originally Posted by shoutbox
