Old 10-29-2012   #1
awdxtc
Drives: 90 awd
Parting out my 90 AWD
It is with great regret I am even considering doing this. I am a full time student and I recently lost my job. I am also trying to get engaged...long story short I am just really low on funds and I have a lot of expenses. I am parting out my 90 awd eagle talon. The prices on the parts are negotiable but not by much as I have shaved money ( in some cases a lot of money) off every part. I have the prices listed but if you want say an entire long block we can work that out, etc. Every part is brand new, ZERO miles and run time. I don't have the car it self listed for sale but I would sell it if someone made me a good offer. It only has 54K on the chassis. If you buy the shortblock I will leave the oil pan on it for 50 bucks it cost me like $200 and I am selling it for $100 buy itself. There maybe things I left out or for got about. You can message me on here with any questions. Please no low ball offers...no I will not sell my dog box for $2000 etc.
Buschur Stage 3 short block $3,000.00 GRP Aluminum Rods, JE pistons, Knife Edged Crank, Bored .030 over
Buschur Race Front mount intercooler $600.00 3 inch inlet and outlet
MSD DIS-2 ignition $400.00
Tial Blow off valve (2) $500.00 ($250 each)
1G Motor Mounts $70.00 New OEM
Front cover assembly Buschur Racing $120.00
ARP head studs $80.00
Alternator relocation kit $100.00
1G AEM EMS (includes wideband) $1000.00
Tial 44MM wastegate (2) $500.00 ($250 each)
1G water pump $45.00
1G $65.00
1G OEM damper $70.00
New 6 Bolt Oil Pan $100.00
Fox Lake Cylinder Head $2,300.00 Ferrea 1 MM over sized valves, Ferrea dual valve springs CNC 5 axis ported
Shep Racing Dog Box Transmission $5500.00 PPG custom straight cut gears (cryogenically treated) bead blasted case (sold pending funds)
Tilton Clutch $4600.00 Carbon Fiber disks, uses a hydraulic release bearing (replaces slave cylinder)
Driveshaft Shop HD driveshaft $650.00 Aluminum driveshaft 3.5” (sold pending funds)
Driveshaft Shop Front axles $530.00 Rated to 650 horse power (sold pending funds)
Driveshaft Shop Rear axles $1,100.00 Rated to 900 horse power (sold pending funds)
Shep Racing Transfer case $1500.00 Cast iron hosing, upgraded output shaft
Custom Ground Crane Cams $900.00 Same cams John ran 7's on
Shearer Fabrications GT4202R Turbo $1300.00 1.15 AR
Tubular Top Mount T4 Manifold Shearer Fabrications $1,200.00
Custom 3.5” Exhaust Shearer Fabrications $1300.00
Custom Fuel sump Shearer Fabrications uses oem fuel tank $200.00
Custom Aluminum intercooler piping Shearer Fabrications $600.00
Fic 2150 injectors $650
Weldon 2025 fuel pump $650
Weldon 10 micron and 40 micron fuel filters $80 each or $130 for the pair
Weldon dial a flow fuel pump controller $400
awdxtc is offline   Reply With Quote
