Old 12-07-2012   #1
Dylan0123
Drives: 95 Talon TSi AWD
FS: 1g and 2g misc. parts, Free Shipping!
Free shipping on everything, price listed is what you pay!
I accept Paypal, my email to send money is: dylan0123@hotmail.com
I don't get on here often so don't pm me
Call or text (217)219-1186
If you see it in the ad, it’s still for sale
Prices are firm
Thanks!
Pictures are at the bottom of the ad, or click here: http://s123.photobucket.com/albums/o...15/For%20Sale/
$2 oem 6cm turbo to exhaust manifold gasket
-new, never used, fits t25 and 14b unported turbine housings
$5 oem o2 housing gasket
-part number MD191897, new, never installed
$10 Exhaust manifold spacer and gasket
-came with an eBay 20G turbo kit, never used
$15 t25 wastegate
-worked great when removed from car
$15 eBay stainless o2 housing
$15 turbo oil return line
-I think it came off a t-25, if you grind/drill out the holes you can use it on a 16G and probably a 20G
$15 oem rear main seal
-part number MD359158, 7bolt, new in package, never opened
$20 Valve cover
-You can see in the pics that it has a 3/4'' x 1/2'' hole in the spark plug valley where one of my rocker arms poked through but it could be welded easily. painted wrinkle black w/ high temp VHT
$20 3x Mitsubishi oem centercaps and 2 retaining springs
$25 emissions parts from ’95 tsi awd: egr valve, evap canister, and purge valve
-was on a 2g w/ 170k miles, unknown operating condition (probably fine though)
$25 oem upper timing belt cover/shield
-2g, black, no cracks or holes, good condition
$30 14b/16g/20g Mitsubishi wastegate
-great condition, works like it should
$30 2g O2 sensor housing
-unported, comes with 3 bolts and the 2 exhaust studs/nuts
$35 oem rear wiper motor and arm
–2g, great condition, worked great, removed for lower weight/cleaner look
$40 Exedy clutch master cylinder
-brand new Exedy ’95-’99 clutch master cylinder, never used or installed
$50 oem knock sensor
–2g, good condition, works great
$85 eclipse low rise wing/spoiler
–2g, gloss black, includes all three pieces, plastic clips and most studs are broken, doesn’t include mounting brackets, there’s some scratches on it from storage
$100 oem manual shifter cables
-part number MD770982, 2g, excellent condition, fits turbo models only (gst, gsx, tsi, tsi awd), they cost $170 new on extremepsi.com and these look almost brand new, just a little dusty from sitting around
$100 trailer hitch for 2g
-came on my ’95 TSi AWD when I bought the car, little bit of surface rust but I spray painted it, comes with a Uhaul trailer light wiring harness
Dylan0123 is offline   Reply With Quote
