Old 12-09-2012   #1
signal15
2004 Mitsu Endeavor AWD - $4900 - price reduced - SE Minneapolis/St. Paul area
Was $6500. I knocked down the price by $1600 because it has power steering issues. I'm done dealing with it, I don't have the time or the patience. The dealer is telling me that a repaired high pressure hose has a fitting that is constricting the flow of power steering fluid and this is the likely cause of the issue. I'm done dealing with it. The hose is $48 online. It's got a brand new pump in it also after all of this.
The power steering DOES work. Just not at an idle.
- 116k miles
- Oil changes always done w/ synthetic
- 3.8L V-6 w/ 225hp
- Black with black interior. Paint is in great shape, and was recently *fully* repainted due to the Mitsubishi black paint recall.
- All wheel drive
- Aftermarket stereo
- New Hankook DynaPro AT tires (about $700). These are all-season tires, but they are GREAT in the snow.
- New brake pads
- New FRAME mounted Curtis 2" receiver hitch (never used even once) and trailer light hookup interface box thingy (this was like $650 worth of stuff)
- 2 year old Odyssey AGM battery. These things are indestructable. This battery will never strand you in the cold.
- HID headlight and ballast conversion.
- LED tail light conversion
- Rear cargo cover/shield
- Rear child restraint hooks for car seats
Great vehicle for the winter or year round.
signal15 is offline   Reply With Quote
Old 12-09-2012   #2
Re: 2004 Mitsu Endeavor AWD - $5800
Pics plz. Maybe I need to try selling our Lincoln again.
Old 12-10-2012   #3
signal15
I'll try to get something up tonight.
Old 12-10-2012   #4
Trogdor
Trogdor's Avatar
Drives: people crazy
Pretty good price for that!
Trogdor is offline   Reply With Quote
Old 12-10-2012   #5
signal15
Buy it!
Old 12-14-2012   #6
signal15
Price dropped to $5400.
Old 12-14-2012   #7
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Pictures would help.
Amsoil Dealer
Old 12-15-2012   #8
signal15
Photos added.
So here's the deal on the power steering. I had a hose get a huge leak and had it replaced. When I got it back, I was having the problem with weak power steering at low RPM's. The shop decided the pump was bad so I had it replaced. It still had the problem, so they thought they got a bad pump and put in another. Same issue.
When they originally replaced the line, they repaired it because no one had it in stock. It appears that one of the fittings from the metal line to the flexible rubber one is smaller than the original, constricting the flow of fluid. I verified with the deal that this is likely the problem, and they said it's VERY unlikely that it's the rack. I'm sick of dealing with it. $5400 for this thing is a damn good price, someone buy it.
Old 12-15-2012   #9
signal15
Here is the part, it's $49:
http://www.mitsubishipartswarehouse....RESSURE%20HOSE
If I'm not rid of this thing by Monday or Tuesday, I'm going to fix it and raise the price.
Old 01-02-2013   #10
signal15
Price reduced to $5100.
Old 01-06-2013   #11
signal15
Reduced to $4900.
Old 01-06-2013   #12
Does this thing have a clean title?
Old 01-06-2013   #13
signal15
Yep. VIN is 4A4MN21S24E016765. Feel free to run it.
