Old 03-28-2013   #1
iceminion
iceminion's Avatar
VR4
Interested in trades.
Low rust, non-minnesotan car, non-hacked, adult owned, huge stack of receipts for work done.
Engine:
3g Lifters, forgot to bleed one, whoops! Will correct before sale.
Leaky valve stem seals, small puff of smoke on startup. will correct soon.
Bottom end was rebuilt a quarter of a million miles ago, stock crank, not machined.
NO LEAKS, have pics to prove it, lost of caked on mud but no wet spots.
Pulley noise, could be water pump, comes and goes. Will correct before sale.
Clean, Dry timing belt.
All exhaust studs replaced
Newer 14b (with receipt)
No boost leaks
Rebuilt Throttle body.
AC intact and converted to r134 does not work.
Leaky flex section.
Running on NT ecu, (does anyone have a Turbo one I can try/buy?)
BRAND NEW NAPA Premium battery.
Transmission:
Shifts well, rebuilt less then 100k ago.
Drivetrain:
Swapped from a limited slip equipped 1991 Eagle Talon
Drivers front axle might be going out.
Suspension:
Rear suspension - BRAND NEW, KYB GR2, with new bumpers and bellows.
Front suspension - older KYB AGX w/coilovers, too harsh, will replace soon.
Drivers Rear Lower ball joint has small amount of play, only ball joint with any play will replace soon.
4ws lines disconnected and no fluid in system.
Brakes:
All stock, sliders greased, great condition, no shakes.
Ebrake works fine, I have additional ebrake lines if you want 'em just in case.
Small tug to the right under heavy braking, bubble in ABS box. ABS box needs to go.
Interrior:
99% complete, and clean, part of the a pillar trim broke.
Turbo Timer
Nice Deck with Color LCD display and 4 aftermarket speakers.
New speedo cable in trunk.
Exterrior:
Windshield has small crack and is missing its trim.
"Dog leg" fell off and is in trunk.
Wheel options:
Talon 1ga 16" Alloys
Talon 1gb 16" Alloys
Talon 2gb 17" Alloys (new tires/will cost more)
comes with full size spare and several extra 205/55r16's
The car really is in good condition, asking 2k or trade, Price reflects current condition. Unibody has 260,xxx miles. A vast majority of the car has been replaced or rebuilt.
ID:	13488   Click image for larger version
ID:	13489   Click image for larger version
ID:	13491   Click image for larger version
ID:	13492   Click image for larger version
ID:	13494   Click image for larger version
ID:	13495   Click image for larger version
building a 3000GT AWD Turbo.
Last edited by iceminion; 04-30-2013 at 08:40 PM.. Reason: more pics, also car runs now
Old 03-28-2013   #2
Re: VR4 #476/1000
damn this would be awesome to have as a dd.
Old 04-02-2013   #3
1999Gst
Drives: 1999 Eclipse,
Re: VR4 #476/1000
Let me know on the offer thanks
651-338-2106
Old 06-02-2013   #4
iceminion
iceminion's Avatar
Re: VR4 #476/1000
SOLD
