Old 04-07-2013   #1
cliford_thefast_redcar
Drives: 95 gsx
still no spark
car still has no spark i have replaced the cam sensor and the cranks sensor.. also put different transistor and different coils in vehicle.. any one have any other ideas or would be willing to come take a look at the car?
cliford_thefast_redcar is offline   Reply With Quote
Old 04-07-2013   #2
LingLing
AznKraut
LingLing's Avatar
Re: still no spark
Post this in the original tech thread you made. Nobody will have any idea of what you're going on about.
Old 04-07-2013   #3
Re: still no spark
Would help if you gave more info on the car and setup.
Do you know that the components you put in were known to be good?
If you have a friend locally with a similar car in working order, you could swap your components on it 1 by 1 until they no longer have spark.
Here's the things I can think of off the top of my head that could prevent spark.
- plugs
- wires
- igniter
- coils
- Cam/Crank angle sensor
- ECU
Old 04-07-2013   #4
Drives: 95 gsx
Re: still no spark
just posted my first post from this thread to my old one... but i have a 95 gsx and i have done the plugs and wires also
Old 04-07-2013   #5
93gtpeater
Drives: cbr 1000rr repsol
Re: still no spark
Check ecu and grounds. Did you check you parts. You need to start at one end and work your way backwards in order. Check spark plugs, spark plug caps, spark plug wires, coil pack, wires leading to the coil, check grounds, check fuses,
Old 04-07-2013   #6
Drives: 95 gsx
Re: still no spark
nvm we just got it running my brother changed the crank sensor last week while i was at work and he installed it 180 degrees the wrong way whoops
Old 04-08-2013   #7
Re: still no spark
I thought you said you had no spark? CAS out 180 would still give you a spark, just not at the right time.
Old 04-08-2013   #8
Re: still no spark
^lol.
Old 04-08-2013   #9
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: still no spark
Exactly what I asked how you diagnosed no spark. lol
Originally Posted by shoutbox
