Old 04-23-2013   #1
Bleeding brakes/clutch
I was looking up how some people do this without a fancy tool, and I saw a guy just using a one-way/check valve in a hose on the bleeder screw so that he could leave it open while bleeding the brakes.
Anyone know where I could score a valve that would be able to stand up again pressure and brake fluid?
I'm thinking just hardware store contraption should work, but I figured that someone on here might of come up with something already.
Thanks
Old 04-23-2013   #2
Jason@DB
Sales Guy
Jason@DB's Avatar
Drives: like it's winter
Send a message via AIM to Jason@DB
Re: Bleeding brakes/clutch
I made one a few years back. I'll check my tool box tonight to see if I have it still.
jason@dbptuning.com
763-428-9882
Jason@DB is offline   Reply With Quote
Old 04-23-2013   #3
93gtpeater
Drives: cbr 1000rr repsol
Why don't you you do it the old way? Have one person pump and another person open the valve.
Old 04-23-2013   #4
I plan on getting some of these. I've always wanted to try them, so I think this project is the one that will get them.
http://www.russellperformance.com/mc...domestic.shtml
Not sure if this is quite what you are talking about, but either way it should make quick work of bleeding the brakes/clutch
Old 04-23-2013   #5
Thanks.
Sometimes I don't wanna wait for someone or bother my wife with it, but I can.
It's like that but you can put it inline in a hose then attach that hose to your factory bleeder. I've just heard a few horror stories about those things and I figured I can buy one check valve for the hose and use it on clutches/brakes on multiple cars.
Old 04-23-2013   #6
Jason@DB
Sales Guy
Jason@DB's Avatar
Mine was a clear hose>check valve>clear hose. I added another hose on the outer end of the check valve to make sure if it did pull anything back in it was fluid, not air.
jason@dbptuning.com
763-428-9882
Old 04-23-2013   #7
If I'm alone, I just top off the master cylinder, then fill up a jar with fresh clutch fluid. Run a hose from the bleeder fitting into the bottom of the jar. Crack the fitting loose, pump the pedal several times until the master cylinder gets low. Repeat that a few times. Button it all up, make sure pedal feels nice and firm. Done.
Here's a pic I found online to kinda give you an idea if I sucked at explaining it:
Old 04-23-2013   #8
^Yeah, that's what I usually do, but this super blue stuff is spendy and I'd like to waste as little as possible, plus last time I almost started sucking up air.
I'll swing by HD racing and see what I find i need to stop there anyway soon.
Old 04-23-2013   #9
As long as you have enough for the brake job that's all that matters because it goes bad soon after you open it. Unless you are trying to do 2 cars on a single can.
I will probably get the wife to hit the pedal when I change fluid next week.
Old 04-23-2013   #10
4seasons69
4seasons69's Avatar
I have a vacuum bleeder and I don't live that far so I could push the pedal for you if need be ;-)
Old 04-23-2013   #11
Bah, I'll just stick to that I guess.
I noticed last time when doing it the traditional way, the jar would be full of the dirty crap and could get back in.
Old 04-23-2013   #12
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Ask friend to borrow fancy tool.
Converted to LS
Old 04-23-2013   #13
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Or just gravity bleed them. No pumping, just crack it open and let gravity do the rest.
When it starts coming out a fancy blue color move to the next bleeder
Old 04-23-2013   #14
I have to do this to mine when I pull it out of storage next week as well.
Old 04-24-2013   #15
LingLing
AznKraut
LingLing's Avatar
I couldn't find my fancy homemade tool. If you need someone to pump the brakes I can stop by after work tomorrow.
Old 04-24-2013   #16
oh I'm in no rush, I'll get to it this weekend maybe.
I have to remove a clutch delay valve from the BMW, flush on the wifes car and a flush on the talon.
Thanks guys.
Old 05-17-2013   #17
dsmolition
chemist
dsmolition's Avatar
Drives: RR Evo 8
How often do you bleed your brakes/clutch that you would ever need something like that?
Old 05-17-2013   #18
I still like Speedbleeders, although my my calipers have different sizes due to replacing them over the years.
Old 05-17-2013   #19
I plan on doing it twice a year, definitely considering a power bleeder. They make a lotus one for $50.
Old 05-17-2013   #20
Depends on how many track days I end up doing, but since I'll have at least 3 cars at all times I'll be doing it a decent amount.
