Old 06-04-2004   #1
Enes
Enes's Avatar
I need a 99 gst/gsx vehicile that would let me try dsmlink v2 on it..
all i would need to do is pull your side panel, unplug the harness from your ecu
plug into mine and swap spark plugs..
Plz if you are willing to let me try this let me know.. call me or pm me.. i am getting an overnighted new chip and need to try it on a different vehicle.
Thank you..
-E
Old 06-04-2004   #2
JasonR
Guest
Tournaments Won: 6
Posts: n/a
I can do this for you. I don't know where you live. My car is 95gsx, but I have cam/crank signal from cas mounted to intake cam on cylinder like 97-99 or 1g. I did this because I did 1g engine swap. Plugs wires allready swapped. So it will serve your purpose I believe. I allready have panel removed so this will be easy access. Only 4 harness connections. Are you doing this to make sure ecu is working? I dont follow. I use dsmlink v1. My number is 952-890-9779. If I can be a help, call, I am at home now waiting for ups delivery.
Old 06-04-2004   #3
JiN
JiN's Avatar
Hey Enes, I have a 99 GST. You know that. If I aint busy and Jason cant make it or something, I dont have a problem with you using my car.
Old 06-05-2004   #4
kram0170
Enes I too have a 2g. As if you didn't know and considering that I'm going to get dsmlink myself soon my car would make a good test subject, so if you still need a car, you know how to get a hold of me.
Have you downloaded the interweb today?
kram0170 is offline   Reply With Quote
