Old 07-07-2013   #1
bigboostingst
bigboostingst's Avatar
Drives: AWD Spyder
TONS of left over Evo/Eclipse parts sale -- FP cams, short blocks, timing covers, TB
My cell phone number is 763-fourzerozero-123five, let me know if you need pictures of anything--
1g/2g Forced performance (FP2) 272 cams SOLD
1g/2g HKS clear timing belt cover (brand new in box, very rare) $200
2g oil pan $30 each
2g head bent valves $100
Evo 8 turbo 9.8 hot side (some bent fins, works perfect) $100
Evo 8 MAS $75
Evo 8 Gates hydraulic tensioner (brand new) $50
Evo 8 Gates water pump (brand new) $40
Evo 8 Injen intake pipe SOLD
Evo 8/9 stock springs $30
2g MAS $40
95-96 Eclipse GSX 5-speed engine wiring harness $100
95-96 Eclipse GSX 5-speed fuse box harness (incomplete) $50
16g internal wastegate $40
2g awd front suspension $60
2g throttle body elbow (great upgrade for the 1g guys) $15 each
2g talon taillights all 3 pieces with bulbs/wiring harnesses $60
2g harmonic balancer $15
2g turbo water pipe $15
2g turbo ac lines $20
2g talon TSI awd mud flaps OEM $100
Greddy 90* intercooler pipe $15
2g stock intercooler $20 each
2g AC belt adjustment pulley/bolt/bracket $10
2g resistor box/pack $25
2g GSX rear brake caliper $25 each
2g GSX front 2 piston caliper $40 each
2g fuel rail $25
2g turbo stock 450cc injectors – Both sets SOLD
2gb Eclipse GST transmission has a bad syncro $50
2g stock exhaust manifold $45
2g oil filter housing $25
2g thermostat housing with sensors $30
2g GST fuel pump hanger $50
2g GSX fuel pump hanger $75
2g stock intake $10
2g manual transmission cables $40
2g stock exhaust manifold heat shield $10
2g stock timing belt cover – top portion - $15 each
2g lower timing belt cover with crack at bottom (works perfect) $20
2g lower timing belt cover $40
7 bolt shortblock out of a 95 eclipse gsx, cylinder walls have developed some rust but was pulled from a running car prior to the timing belt snapping $100
7 bolt shortblock was recently rebuilt I’m not sure on condition/compression since I never ran it. $100
Old 07-07-2013   #2
89_Colt_GT
89_Colt_GT's Avatar
Drives: Swifty Crazy
Re: TONS of left over Evo/Eclipse parts sale -- FP cams, short blocks, timing covers,
How good of shape are your oil pans in?
1989 Colt GT
2013 Ford Focus
1999 Buell M2
89_Colt_GT is offline   Reply With Quote
Old 07-09-2013   #3
bigboostingst
Drives: AWD Spyder
Text me and I'll send you some pics. List updated!
Old 07-09-2013   #4
vish
vish's Avatar
Drives: 95 tsi
Do you have a good set of coil packs laying around?
vish is offline   Reply With Quote
Old 07-09-2013   #5
Sypher651
Sypher651's Avatar
Drives: 1998 Eclipse Spyder
will your 2g thermostat and housing work with a 98 spyder gs? Same with the Evo 8 intake pipe?
Sypher651 is offline   Reply With Quote
Old 07-11-2013   #6
bigboostingst
Drives: AWD Spyder
Sorry I do not have a set of coil packs. I have half a pack laying around somewhere. I can dig it up if that's all you need.
I don't believe the Evo intake will fit on your gs since it is made to come right off the turbo (vs yours off the throttle body). Although maybe it would since they use the same MAS. Do some research on dsmtuners and I'm sure you will find your answer.
Old 07-15-2013   #7
bigboostingst
Drives: AWD Spyder
Injectors and cams sold!
Old 07-17-2013   #8
dogwhistle
dogwhistle's Avatar
Thanks for the cams! Looking forward to putting them to good use.
Old 08-07-2013   #9
bigboostingst
Drives: AWD Spyder
My pleasure, can't wait to see your build thread!
Old 08-12-2013   #10
bigboostingst
Drives: AWD Spyder
Everything on this list is OBO.
Old 09-06-2013   #11
wildman38
wildman38's Avatar
Drives: 95 talon tsi fwd 2.3 fp green
Do you still have the hks timing belt cover?
wildman38 is offline   Reply With Quote
Old 09-08-2013   #12
bigboostingst
Drives: AWD Spyder
A few more things sold.
Old 09-18-2013   #13
bigboostingst
Drives: AWD Spyder
Intake + fpr sold.
Old 11-12-2013   #14
bigboostingst
Drives: AWD Spyder
Bump Bump Bump
Old 11-12-2013   #15
dogwhistle
dogwhistle's Avatar
Kyle is an honest and great help! Still rocking the FP2 272 cams and was impressed with how great of shape they were in. Thanks and hope the rest sells! I'd love to pick some of those up when the budget rises :P
-Adam
aneujahr@maperformance.com
Old 11-12-2013   #16
bigboostingst
Drives: AWD Spyder
Thanks a lot Adam! You still gotta start a project thread at some point, I'd really like to see what you've built!!!
Old 11-16-2013   #17
dogwhistle
dogwhistle's Avatar
I have a facebook album that i'll try to make public and share on here or try to embed. So far the thing is an animal! Thanks! Sorry back to parts for sale ha
-Adam
