Old 09-17-2013   #1
awd laser
awd laser's Avatar
Drives: 93 TSI
Need a welder! Will Pay!
I ordered a Thermal R&D cat back for my 2g awd. Custom car central said it was a true 3in exhaust but when I received the kit, the exhaust ended up being a 2.25in cat flange that expands to a 3in pipe. I just need someone who can cut 3in off of the flange that connects to the place where the catalytic converter use to be. I have an apexi downpipe that is 3in all the way that eliminates the catalytic converter therefore the catback will not bolt up to my downpipe.
Long story short, can anyone cut and weld a new 3in pipe with a flange for me? Im willing to bring the pipe to you this weekend to get it done and I'll throw some cash on top. Or if anyone knows a shop that will do it for cheap that'd be great too!
Old 09-17-2013   #2
awd laser
awd laser's Avatar
Drives: 93 TSI
Re: Need a welder! Will Pay!
As you can see in the picture I just need that short 2.25in section cut off and replaced with a 3in section with a flange.
Old 09-17-2013   #3
93gtpeater
Drives: cbr 1000rr repsol
I could do it but I would only do it if the exhaust is on the car. I don't want to weld the flange on wrong and not have it line up.
Old 09-17-2013   #4
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
^^ I'm in the same boat as this guy.
I would do it, otherwise.
Style's automotive engineer
Old 09-18-2013   #5
Paging JET and/or Pushit2.0
Old 09-18-2013   #6
Does the flange on the downpipe rotate at all, or is it welded on? If it rotates, it wouldn't be that risky to do it off the car.
Old 09-18-2013   #7
s1ngletracker
Drives: A BMW
I'd be surprised if it rotates. I could eyeball it, but its always safer to tack things up on the car.
Old 09-18-2013   #8
awd laser
awd laser's Avatar
Drives: 93 TSI
Any of you guys near Maplewood? The downpipe is already on and I have the hangers so we could put the exhaust up and go from there. And no the flange does not rotate.
Old 09-18-2013   #9
93gtpeater
I am in oakdale
Old 09-18-2013   #10
awd laser
awd laser's Avatar
Drives: 93 TSI
Ohh perfect! You know where I can find the pipe and flange? Will I have to go to MAP? Or can I go to autozone or something?
Old 09-18-2013   #11
93gtpeater
I am not sure where you can find one
Old 09-18-2013   #12
awd laser
awd laser's Avatar
Drives: 93 TSI
Hmmm ill look around. Will you be available on Saturday?
Old 09-18-2013   #13
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
You should be able to get a mild steel 3 inch 3 bolt flange at any auto parts store. A 3" stainless flange and pipe might be a little harder to find. If you go to a custom exhaust shop they might give you a short piece they cut off something else. I could weld it for you too but it wouldn't look as nice as the rest of the exhaust because I only have a MIG.
11.35 @ 120mph
Old 09-18-2013   #14
What do you need, just a small length of 3" SS pipe and a 3" 2-bolt flange? I'll check to see if I have any scraps laying around at home.
Old 09-18-2013   #15
awd laser
awd laser's Avatar
Drives: 93 TSI
Ill call a few exhaust shops and see what they have. Halon if you can find one that'd be great! Let me know if you do!
Old 09-18-2013   #16
awd laser
awd laser's Avatar
Drives: 93 TSI
I don't really care for looks. Im fine with it as long as it works and doesn't leak. It's under the car anyways.
Old 09-18-2013   #17
I found a small section of 3" stainless exhaust tube in my scraps. It's about 7.5" long. Not sure how long of a piece you need but it's yours if you want to come pick it up in Blaine.
Old 09-18-2013   #18
awd laser
awd laser's Avatar
Drives: 93 TSI
Perfect I only need about 3-4 inches! Ill be there Saturday morning, will that work for you?
Old 09-18-2013   #19
We will not be around for most of Saturday. I could just leave it outside on the front porch for you though.
Old 09-19-2013   #20
awd laser
awd laser's Avatar
Drives: 93 TSI
Yeah that's fine! Thanks!
