Old 11-05-2013   #1
Yiddie
Yiddie's Avatar
Drives: 98GSX
FS: 02 Subaru Legacy L Edtion
Seeing if anyone is interested.. 2002 Subaru Legacy L Edition automatic, just hit 214k Miles don't let the high mileage scare you tho.. Car drives great, No leaks. Last winter had rear rotors and brakes,fuel filter, air filter replaced,all new fluids. New head gasket(done by Lake Country Toyota) New winter tires put on last February. Just replaced front rotors and brakes this fall. No exhaust leaks either. Everything works on the car. Car is only driven in the winter time. The AWD Makes it handle great in the winter. Also comes with a extended warranty which covers pretty much everything mechanically, engine components,drivetrain components, etc.. $0 deductible, 24/7 roadside assistance. Yes I have used this warranty before and it's fantastic. Asking $3500
ID:	14076   Click image for larger version
ID:	14077   Click image for larger version
Yiddie is offline   Reply With Quote
Old 11-05-2013   #2
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
Re: FS: 02 Subaru Legacy L Edtion
Did toyota do just one headgasket or both? Did they replace timing belt/water pump at the same time? Does your warranty transfer to the new owner?
Old 11-05-2013   #3
Yiddie
Yiddie's Avatar
Drives: 98GSX
Head Gaskets replaced and heads machined. Timing belt inspected and didn't need to be replaced. Timing belt and water pump have been replaced before. The owner before me had receipts of every maintenance work done all in the glove box. And yes the warranty is transferable.
