Old 11-17-2013   #1
vassil
Been there, done that.
vassil's Avatar
Vassil's 9-second 859WHP Talon Partout
The time has come to part out my pride and joy. All parts in the car have been purchased new and have about bunch dyno pulls and roughly 15 passes. The car is a 1GA Talon. It made 859WHP when it was a manual. After converting it to an Auto it made 728WHP. The best pass as a manual was a 10.04@152 and the best pass as an auto was a 9.85@143.
Here is a video of the car showing dyno pulls and it's 9 second pass.
http://www.youtube.com/watch?v=Syp8AsOwENw
Shortblock - $2000
  • 2.4 Long Rod
  • ARP Main Studs
  • Kiggly Girdle
  • Eagle Crankshaft
  • Ross 9.0:1 Pistons
  • ACL Tri-Race bearings
  • Pauter Rods
Head - $1100
  • Engintecs one-off head with all bells and whistles (made 859Whp on a 6266)
  • Ferrea 1mm oversize valves
  • Killer port work
  • 5-agnle valve job
  • Viton Seals
  • Kiggly dual valve springs
Misc Engine Parts
  • Fluidampr Crank pulley - $150
  • Magnus A-1 Headstuds - $120
  • Kelford 280 Cams - $500
  • Custom Lollipop Red Valve Cover with -10AN Lines & Dual Chamber catchcan with -10AN lines - $250
Cooling
  • Fluidyne Radiator - $150
  • Setrab Oil Cooler -10AN Lines - $100
  • STM Auto Trans Cooler with -6AN Lines - $120
Intake / Exhaust / Turbo
  • Garret 4 inch Intercooler with 2.5 inch inlet/ 3 inch outlet - $600
  • 3 inch upper intercooler pipe / 2.5in lower intercooler pipe - $150
  • Magnus V3 Cast Intake Manifold - $800
  • FFTEC 75mm Throttle Body (/w billet ISC Adapter) - $150
  • Punishment Racing tubular T3 header & O2 Housing - $750
  • Tial 44mm wastegate with dual springs - $200
  • Precision Billet 6266 Ball-Bearing Turbo T3 /.82 AR - $1150
  • Hallman Pro RX Manual Boost Controller - $85
  • Tial 50mm blow off valve - $180
  • Custom 4" Cold-Air intake with K&N Cone Filter - $120
Fuel
  • FIC 2150cc Injectors - $600
  • Magnus -10AN Fuel Rail - $100
  • Turbosmart FPR-3000 Fuel Press Regulator (-10 feed /-10 return) - $200
  • FueLab 82803 Fuel Filter (-10AN in and out) w/Aeromotive Fuel Pressure Gauge - $80
  • Full-Blown Billet Pump Housing w twin walbro 255HP pumps - $285
  • -10AN Feed Line / -8AN Return Lines (stock tank) - $150
  • Dual Aeromotive 340lph pumps - $250
Suspension & Chassis
  • Shell (10pt Chromoly Rollcage certified to 8.50) - $1500
  • Kirkey Seats - $250
  • G-Force Camlock 5-point harnesses - $100
  • Team Dynamics Pro Race-1 wheels (12 lbs) with MT ET DRAG 26 X 8.5 - $800
  • Megan Coilovers - $600
  • Jay Racing Rear Toe Eliminator Kit - $100
  • Tubular rear Lower control arms - $100
  • Tubular Rear Upper control Arms - $100
  • Buflfab 1-pc Front Crossmember - $125
Drivetrain
  • IPT Built Auto Trans with welded center diff - $650
  • Bradco Torque Converter - $1000
  • Kiggly Flexplate - $100
  • 4-Bolt Rear Diff & Axles - $250
  • Auto Transfer Case - $100
  • Manual Trasfer Case - $75
  • Auto Front Axles - $150
Electronics
  • DSMLink v3 rwith 1G ECU - $550
  • GM AIT Sensor - $15
  • AEM 5bar map sensor - $100
  • Innovate Motorsports LC-1 Wideband with Gauge - $175
  • Stweart Warner Boost & Oil Pressure Gauges - $50
  • Dynatek ARC-2 ignition amplifier - $250
  • Hella Vaccum Pump - $120
  • Forced Four Shiftbox plus - $150
Brakes
  • TCE Willwood 11.5" 4-piston with scalloped rotors (Front) - $850
  • TCE Willwood 11.5" 2-piston with scalloped rotors (Rear) - $600
  • CNC Staging brake - $100
  • Big Brakes with Powerslot Rotors & Brakeman Pads - $220
Exterior
  • 1GA VIS EVO Carbon Fiber Hood - $350
  • Fiberglass Hatch with Lexan rear window (from John Shepherd's 7 second Talon) - $350
Nitrous
  • Zex Nitrous 10lb bottle, lines, Pro 250shot selenoid (Dry) (30,50,75 jets) - $500
Manual 859.8WHP / 642 ft/lbs
10.23@152
Automatic 728WHP / 517 ft/lb
9.85@143
1G DSM Crossmembers
BulFab
Old 11-17-2013   #2
twack
It was a auto get over it
twack's Avatar
Re: Vassil's 9-second 859WHP Talon Partout
This is a sad day! i wish i was still an auto i would grab that trans in a heartbeat
Old 11-17-2013   #3
dogwhistle
dogwhistle's Avatar
I've never seen a parts list where I literally want everything. Sorry to see it parted though :/
-Adam
aneujahr@maperformance.com
Old 11-18-2013   #4
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
I hate you! lol
Originally Posted by shoutbox
Old 11-18-2013   #5
Mark Leasure
Mark Leasure's Avatar
PM'd for rims and tires.
www.maperformance.com
Old 11-20-2013   #6
vassil
vassil's Avatar
Jake, your turn to brake parts next year Just kidding ... LOL
10.23@152
9.85@143
1G DSM Crossmembers
BulFab
Old 11-21-2013   #7
dsm_talontsi
dsm_talontsi's Avatar
Drives: 91 Eclipse GST
Oh my! I want so badly. How much for whole car?
dsm_talontsi is offline   Reply With Quote
Old 11-29-2013   #8
dsm_talontsi
Pm sent
Old 12-02-2013   #9
dsm_talontsi
Looking to get upper and lower icp. Possibly whole turbo setup if we can make a package deal. Iat sensor. Map sensor. Call me so we can discuss further. 612 876 8827
Old 01-21-2014   #10
Still have the hood?
Old 01-22-2014   #11
dsmolition
chemist
dsmolition's Avatar
Drives: RR Evo 8
pm sent
Old 01-22-2014   #12
1999Gst
Drives: 1999 Eclipse,
Pm sent
Old 01-22-2014   #13
SlowWhite
SlowWhite's Avatar
Pm sent
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
Old 01-22-2014   #14
dsmreck
dsmreck's Avatar
Drives: 98 gsx
he hasn't been on here for 3 weeks
Old 01-23-2014   #15
dsmolition
chemist
dsmolition's Avatar
Drives: RR Evo 8
I am aware.
Old 01-23-2014   #16
dsmreck
dsmreck's Avatar
Drives: 98 gsx
just saying he hasn't returned a pm for along time but thats cool that you are an aware person on your own.
Old 02-04-2014   #17
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
If he hasnt returned any of your messages, I'll give him a shout and tell him to check this. I know he had to leave the country for 2 weeks due to a family emergency.
Old 02-04-2014   #18
dsmreck
dsmreck's Avatar
Drives: 98 gsx
that would be kinda cool ^ tell him i'll take the cams 2150's and wheels tires. No rush family first.
Old 02-04-2014   #19
^ I know Leasure already bought the wheels. The shell along with the hod is also gone.
Old 02-05-2014   #20
dsmreck
dsmreck's Avatar
Drives: 98 gsx
^good to know still up for the injectors and cams for sure.
