Old 12-11-2013   #1
89_Colt_GT
89_Colt_GT's Avatar
Drives: Swifty Crazy
Lincoln 300amp Welder - $1600
Who: Erik
What: Lincoln K2416-1, Power Mig 255c welder
Where: White Bear Lake
How: text 651-315-1081
Price: $1600 b/o, will do partial trade for handgun, Glock, .22lr rifle/pistol.
Also Listed on Ebay.. http://www.ebay.com/itm/Lincoln-Powe...item3a888fdcf2
Features:
  • Diamond Core Technology, a patented choke design
  • A forgiving arc, even with large stickout changes
  • Excellent out-of-position arc action
  • A wide voltage sweet spot at a given wire feed speed
  • Low spatter
  • Rugged cast aluminum industrial wire drive features dual driven rolls, easy-turn numeric tension indicator, brass-to-brass gun connections and Lincoln’s 100% wire-supporting split wire guide system.
  • Digital meters display, preset wire feed speed and voltage, and actual amperage and voltage while welding.
  • Generous 15 ft. (4.5m) gun and cable assembly makes it easy to reach your work.
  • The most economic spool gun solution in the 250A category – costing hundreds less.
  • Spool Gun Ready - The Power MIG 255C has the electronics built-in to drive either the Prince® XL spool gun or the Magnum® SG spool gun. A second gas solenoid is also built-in for spool gun use.
  • The Power MIG 255c features a 115v auxiliary receptacle to power a grinder or other auxiliary equipment in your work area.
Includes:
  • Power MIG 255C Power Supply
  • Magnum 250L gun
  • 15' quick-connect cable assembly with fixed gas nozzle assembly
  • Work Clamp And Cable
  • 10' 230V input power cable with plug
  • .035"/.045" drive rolls and guide for steel
  • Gas regulator and hose kit for CO2 or Argon blend gases
  • Near Empty C25 tank
  • Lincoln Autodim Helmet ($140 value)
  • 50-foot 220v extension cord
  • 95% left of .035 spool
  • Spare inner lining for wire feed
Info from my craigslist ad...
It's been a nice tool around the house. Works fantastic. You will not be disappointed. Wasn't used for commercial. Just odds and ends around the house, hasn't been on for more than 3 hours at a time.
http://www.summitracing.com/parts/lcn-k2416-1
My pricing is just right: http://minneapolis.craigslist.org/cs...222479864.html
Will take an Assault Rifle/pistol on part trade. I have a p2p.
Erik
651-315-1081
ID:	14108   Click image for larger version
ID:	14109   Click image for larger version
1989 Colt GT
2013 Ford Focus
1999 Buell M2
89_Colt_GT is offline   Reply With Quote
