Old 02-04-2014   #1
HID Flickering issue
I was driving my car home tonight and the pass. side headlight was randomly flickering, turning on/off while I was driving.
Could it be dying? I'm clueless on HIDs. This is the factory setup on my '02 330i.
Thanks
Old 02-04-2014   #2
Speedfreak
Drives: four tires
Re: HID Flickering issue
Most likely the ballast. Google your car + ballast and see what you come up with.
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 02-04-2014   #3
dsmreck
dsmreck's Avatar
Drives: 98 gsx
I would say its the factory hid relay box. you'll need to just replace that. you can usually find an aftermarket one. if you want i can send you the schematic tomorrow.
Old 02-04-2014   #4
polishmafia
Smells like cat poop
polishmafia's Avatar
Not sure how your car is setup, but you could try to swap the bulbs from side to side and see if the issue is still present. If so, then its most likely the ballast. If it moves to the other side, then you may have a bulb issue (although very uncommon).
Old 02-04-2014   #5
Bulb went bad in my envoy. It would ignite but then go super pink and dim. Id do like pete said and swap the bulb to the other side, should help narrow things down.
Old 02-05-2014   #6
dsmreck
dsmreck's Avatar
Drives: 98 gsx
^ those are possible just going by what is the most common issue we see with factory hid. i bet it's the relay, bulb, or ballast hahaha
Old 02-05-2014   #7
I've had to replace bulbs and ballasts in HID cars, could be either.
Old 02-05-2014   #8
dsmreck
dsmreck's Avatar
Drives: 98 gsx
absolutely just adding another possible failure point.
Old 02-05-2014   #9
Thanks guys, no issues this am driving to work. I'll keep an eye on it and see what happens but at least I know some things to try now.
