Old 03-08-2014   #1
DSM_brother2
Drives: to the shop
1g auto starter noise
i swapped out a motor with bad compression and put everything back in and now i have a crazy noise when i start it. everything i needed came off the old engine and i put onto new 6 bolt. have tried 2 differernt starters with same results.
any ideas? here is a video of noise
http://youtu.be/SFQgSs40YVU
93 talon tsi/ 6 bolt swap
Mitch
Old 03-08-2014   #2
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: 1g auto starter noise
Sounds like it has 1 working piston
2006 WW IX RS 396/404 - SOLD
Old 03-08-2014   #3
DSM_brother2
Drives: to the shop
Motor is fine. Starter noise is what I'm refering to
Mitch
Old 03-09-2014   #4
b00sted_spyder
Maybe ring gear on the flywheel is chewed up?
Old 03-09-2014   #5
DSM_brother2
Drives: to the shop
Would think but we pulled trans ans switched torque converters to a nice clean one
Mitch
Old 03-09-2014   #6
b00sted_spyder
So it's an auto transmission? Did the flex plate ring gear look good where the starter turns it? Maybe the inspection shield is rubbing on the flex plate? Or maybe you forget to tighten down a torque converter bolt? Kind of hard to tell where the sound is coming from in the video.
Old 03-09-2014   #7
Did you reuse the auto starter plate if it was a 5 speed engine.
Old 03-09-2014   #8
DSM_brother2
Drives: to the shop
Auto trans. Same starter plate was used, swapped all parts over
Mitch
