Old 06-18-2014   #1
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
1g Partout!
1994 Eagle Talon TSI AWD - Full part out!
Sold items will be deleted from list.
Small stuff not listed I likely have so ask me!
If you want specific pictures of anything text me
I’m located in South Minneapolis……AJ 503-504-2809
Stock 4g63t longblock (w/ARP head studs, balance shaft elimination)
about 140k miles on it, virgin block and crank, low compression.
(Compression readings 135-90-135-135) - $300
All 4 poly motor/trans mounts
(pretty much brand new) - $100
Kosei 17" wheels with newer Bridgestone Potenza RE970AS tires (225/45/17). Wheels were spray painted black and could definitely use refinishing. - $300
Interstate MT-51 500CCA battery
(bought new 3 months ago) - $80
Nice tinted 1GB tail lights (high quality not night shades) - $40
1gb clear corner lights - $10
Injen intake pipe - $30
CAS green top - $20
Front Lower Control Arms, both sides, fresh bushings/ball joints
(have about 60 miles on these since new) - $60 for the pair or $30 each
FIC 1250cc fuel injectors - $300
New 1g turbo/manual stock FPR - $20
1g instrument cluster, shows 129,052 miles, has carbon overlay - $40
Stock 1g (turbo, manual trans) Eprom ECU - $60
1g non-cruise control throttle cable - $20
1g rear strut bar - $20
22 spline transfer case - $100
1g awd driveshaft - $60
1g awd fuel tank - $50
OEM clutch master (less than 1000 miles on it) - $50
OEM slave cylinder (less than 1000 miles on it) - $50
LSD 4-bolt rear diff w/axles
(complete rear subframe available) - OBO
Front AWD CV axles (and a few intermediate shafts) - $40 each
1g awd front dual piston calipers w/lines - $50 for the pair
Old 06-18-2014   #2
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Re: 1g Partout!
How's that Stage 4 feel?
Old 06-18-2014   #3
dsmghost
dsmghost's Avatar
Re: 1g Partout!
Feels great, no grinds or popouts, smooth up or downshifting. My car was 350-400awhp and I never brought it past 7k rpm. I bought it from 4seasons69 his car was around 700awhp and he said it shifted good over 9k rpm the few times he went that high.
Old 06-18-2014   #4
Re: 1g Partout!
Old 06-19-2014   #5
dsmghost
dsmghost's Avatar
Re: 1g Partout!
Bump
Throttlebody sold, interest in headlights
Old 06-20-2014   #6
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: 1g Partout!
Did the shell have ABS?
Style's automotive engineer
Old 06-20-2014   #7
Re: 1g Partout!
Nope. I deleted it when I had the car.
Old 06-20-2014   #8
dsmghost
dsmghost's Avatar
Re: 1g Partout!
Boost gauge sold, updated list, more parts to add, pics to come
Old 06-21-2014   #9
dsmghost
dsmghost's Avatar
Re: 1g Partout!
Pictures added, more to come.
Old 06-21-2014   #10
Re: 1g Partout!
What kind of shape is the valve cover in?
Old 06-21-2014   #11
dsmghost
dsmghost's Avatar
Re: 1g Partout!
Has a small crack under one of the inside bolts I covered with a glob of rtv haha.
Old 06-22-2014   #12
dsmghost
dsmghost's Avatar
Re: 1g Partout!
Headlights sold! Added some pics to first post
V3 and injectors pending sale
Old 06-23-2014   #13
s1ngletracker
Drives: A BMW
Re: 1g Partout!
So that means it still has ABS front hubs though?
Old 06-23-2014   #14
Re: 1g Partout!
It should yea unless AJ replaced them.
Old 06-23-2014   #15
dsmghost
dsmghost's Avatar
Re: 1g Partout!
I'm 90% sure I threw out the tone rings when I replaced the front wheel bearings. Either way for now the shell is staying as a roller.
Old 06-23-2014   #16
s1ngletracker
Drives: A BMW
Re: 1g Partout!
shoot. I woulda traded you knuckles.
Old 06-23-2014   #17
dsmghost
dsmghost's Avatar
Re: 1g Partout!
VRSF FMIC kit ,Turbo, Exhaust, front seats, rear seats, radiator, slim fans, speed density bundle, 2g manifold, boost control solenoid, all SOLD!!
Old 06-23-2014   #18
dsmghost
dsmghost's Avatar
Re: 1g Partout!
Shep stage 4 trans and clutch kit SOLD!!!
Old 06-25-2014   #19
dsmghost
dsmghost's Avatar
Re: 1g Partout!
list updated, and new pictures
Old 06-25-2014   #20
dsm_talontsi
dsm_talontsi's Avatar
Drives: 91 Eclipse GST
Re: 1g Partout!
dsm_talontsi is offline   Reply With Quote
