Old 07-04-2014   #1
dsm_talontsi
dsm_talontsi's Avatar
Drives: 91 Eclipse GST
91 FWD DSM
Bought the car from dsmdolney. Head gasket went so I replaced it and re used timing stuff. Ended up snapping the belt and fucking the motor up. So I swapped my motor from last year into it. Has less than 10,000 miles on it. Then the trans went, so I bought tkrs 99 fwd trans and swapped that in. Now it runs and drives fine. Just oil leaks and motor Mounts need replacing.
Rebuilt 6 bolt with 2g Pistons 1g big rods, acl race bearings, hastings rings, bs eliminator kit, polished crank, felpro permatorque composite head gasket New gates timing kit, water pump, (less than 10, 000 miles)Evo springs/retainers, New stock valves
Stock 14b 15psi
New plugs (ngk bpr7es) and wires*
AGX Springs
2.5in exhaust
AC removed
Fiav bypass plate
Homeade 2g orange paint job (not the greatest, some overspray)
Purple powder coated wheels
I want $2500 after everything I've done.
Call me if interested 612 876 8827
dsm_talontsi is offline   Reply With Quote
