Old 07-14-2014   #1
Scheides' Epic Mitsu Garage Sale - DSM, Evo, EvoX parts
Cleaning out the garage!
NO REASONABLE OFFER REFUSED!
Combo offers welcomed.
Can ship if need be but I would prefer to just meet-up/deliver.
Txt me: 612.eight-five-ohhhhhh.1407
PM: scheides
email: chris-at-snowsecurity.com
Evo Front Windshield Wiper Cowl $10.00
Evo ebay 3" downpipe $40.00
Evo OEM Exhaust, no cat, 8k miles $100.00
Evo GSR Stock Suspension, missing one top hat $125.00
Evo GSR Front Shocks $30.00
Evo 7-bolt front case/oil pump/used $40.00
Evo Valvesprings (evo9--no retainers) $30.00
Evo Evo9 cams $40.00
Evo Infinity Amp + Deck $20.00
Evo Stereo Deck $10.00
Evo Front Passenger Airbag $50.00
Evo Rearviewmirror $10.00
Evo ACT Clutch (used) $25.00
Evo Flywheel $25.00
Evo ACT Throw out Bearing $5.00
Evo Airbox - bottom $5.00
Evo OEM intake $5.00
Evo Front Right Knuckle, ABS Sensor $50.00
Evo Rear Right Knuckle, wheel bearing, ABS Sensor $50.00
Evo Right Rear Lower Control Arm $30.00
Evo MR Coilsprings $30.00
Evo Front Wheel Bearing (good) $50.00
Evo SSL Plastics (per piece, let me know what you need!) $5.00
Evo Center counsole $35.00
Evo Exhaust manifold heat shield $10.00
Evo Window Motors + tracks (each) $15.00
Evo ACD Assembly - bad $10.00
Evo Balance shaft (set) $15.00
Evo Crank pulley $40.00
Evo cam gear $10.00
Evo Idler, Tensioner, Water pump pulley set $30.00
Evo crank pulley $15.00
Evo crank trigger plate $10.00
Evo timing tensioner $10.00
1G DSM 23-spline t-case $80.00
EvoX Flywheel $25.00
EvoX Front Rotors (used) $30.00
2G DSM Roll stop inserts $5.00
2G DSM Mint! Radiator brackets $10.00
2G DSM Throttle Body Elbow $10.00
3/S OEM Fuel pump $10.00
2G DSM Stock Fuel Rail $10.00
2G DSM Cylinder Head (clean--can be used for core) $75.00
2G DSM Battery Tray Plastic $5.00
