Old 09-19-2014   #1
Anyone using a Walbro 450 E85 pump?
Anyone local used one with success?
Got an offer on one, but I haven't heard great feedback about it.
Old 09-20-2014   #2
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Anyone using a Walbro 450 E85 pump?
I ran that last year, on my 6266, didn't have any issues with it.
I think Scheides is also using one, or maybe he is still on the normal 450 not the e85 one.
Besides fitment changes that were needed, no problem running mine.
Old 09-20-2014   #3
dsmDolney
dsmDolney's Avatar
Drives: Racecars
I am on the e85 one works good with the 35r.
Tyler
2011 Subaru Sti 11.0 @135mph
Old 09-20-2014   #4
I'm talking pushing it to over 80psi fuel pressure.
35+psi on top of standard 43.5 base fuel pressure.
Seems like a few are having issues with higher boost levels.
Old 09-20-2014   #5
Murlo26
Murlo26's Avatar
I ran 32psi and my base fuel pressure was 50 or so as that is all the lower I could get it with the 450 hardwired and my return setup.
So I was over 80psi but I ran out of pump at that point too, so who knows.
Old 09-20-2014   #6
ok, well that helps. thanks.
Old 09-21-2014   #7
dogwhistle
dogwhistle's Avatar
I believe Bobby also ran that in his last Evo and had great results.
-Adam
aneujahr@maperformance.com
Old 09-21-2014   #8
I've had one for....idk I can't remember how long. Years now. It's seen up to 36psi, made all the difference over my DW300. I'm running the non-e85 w400, it's been on a BAP its entire life and on my X I had to bore out the siphon but other than that no major issues. Running on a lightly modified stock FPR and aftermarket rail to get base pressure nice and low.
Works great, hella bang for your buck.
Old 09-22-2014   #9
Tachyon
Tachyon's Avatar
Drives: Icarus
I also have one... upgraded when I ran out of pump with a single 255HP. Pump works amazingly well when your fuel line does not have a hole in it. Although I run kiddy boost compared to some of folks here, it definitely has enough fuel flow for mid 10's on a 20g.
-Sebastian Vettel
Old 11-02-2014   #10
dsmreck
dsmreck's Avatar
Drives: 98 gsx
I ran the 450 also. Beast of a pump
