Old 09-29-2014   #1
dsmreck
dsmreck's Avatar
Drives: 98 gsx
98 gsx built to the nuts
1998 mitsubishi eclipse gsx 138,926 5 speed
motor built by motors by gosh
2.0L 6 bolt
.020 over block
wiseco e85 hd2 10.5:1
manley tt i beams
acl race bearings
kiggly main brace
arp main studs
arp l19 head studs
6 bolt ported head
mitsubishi mls head gasket
supertech ss nitrate valves
kiggly beehives
kiggly hla
gsc s3 cams
punishment racing t3 hot side kit
garret gt 3582 dbb turbo
jmfab drag intake manifold
s90 70mm throttle body
vrsf front mount intercooler
punishment 3 inch down pipe to full 3 inch exhaust
fresh trans
lsd rear diff
new alternator
jm fab small battery kit
jm fab catch can 10an
godspeed aluminum radiator
mitsubishi valve cover 10an
walbro e85 450 fuel pump
6an fuel feed
aeromotive afpr 6an to 6an return
fic 2150cc injectors
fic fuel rail 6an to 6an
tial 50mm bov
tial 44mm waste gate with tial dump tube
fidanza adjustable cam gears
gates racing timing belt
kiggly crank trigger
boomba racing rear diff cover
innovate mtx gauges
dsmlink v3 full on speed density
enkei 17 wheels with goodyear eagle f1 tires
solid diff mounts
urethane engine mounts
fp intake
k&n filter
halman pro boost controller
carbon fiber hood
talon twisty side skirts
competition clutch twin disk clutch
i'm sure i am forgetting things here but thats a good start to the list. most everything has less than 500 miles on them as I started the build this winter. The car has been torn down and there is no rust or any issues at all. I have wire tucked the engine bay and taken out the power steering, also cut the spare tire well out, i also stripped a lot of weight out of the car, but nothing to affect its ability to drive safely. most everything that can be powder coated is. I have replaced axles, driveshaft, shocks, wheel bearings, control arms, etc etc. I have put on 200 or so miles on the car this year and the car is set at 20psi wagegate pressure for now and I have not pushed it any farther yet. I can easily tune the car on high boost for someone if they want me to. This is easily a 10 second car. I will also include all of my spare parts with the car if they are wanted. The car is great, but its time for me to get a 4 door. I am asking $12k, I have well over $20k invested in two years so trades will reflect that. I would be interested in evo's, trucks, suv etc. I know its almost winter so before the snow flies i will be storing the car. call or text me Nick 218259o576.
