Old 10-14-2014   #1
blesi660r
blesi660r's Avatar
fuel pump hanger cover
So like most have delt with, all the 8 mm nuts/studs broke on the hanger cover or what ever it's called, I have a few ideas on how to fix this once I can get the damn line lose lol. I am just curious on how others have fixed this issue?
I drained the tank etc. And am going to grind down the broken studs then drill them out, then replace with stainless bolts. Now I've seen ppl use a little jb weld to hold the studs in place, not sure if I really want to use jb on the inside of the tank? I seen a kit that ppl have used to fix this and cannot find where it was purchased so I could mimic it.
Just couldn't stay away.
Old 10-14-2014   #2
blesi660r
blesi660r's Avatar
Re: fuel pump hanger cover
Was on tuners for a bit but haven't come up with the right key words I guess to bring up any threads about this issue.
Old 10-15-2014   #3
blesi660r
blesi660r's Avatar
So not a single person has had to deal with this lol, I'll do a Wright up then .
Old 10-15-2014   #4
New tank?
Old 10-15-2014   #5
blesi660r
blesi660r's Avatar
Lol no way, some stainless bolts and an idea I've got.
Old 10-16-2014   #6
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
http://mitsustyle.com/forums/showthr...ight=fuel+tank
He ended up replacing his it looks like, he might have a few tips.
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 10-20-2014   #7
gsxvince
the dsm mechanic!
Drives: 1991 talon tsi 1ga
Ive drilled out the studs and then tapped the holes with the same size thread and then screwed bolts from the inside up and jb welded them in as long as you get them straight it works great
gsxvince is offline   Reply With Quote
Old 10-20-2014   #8
blesi660r
blesi660r's Avatar
This is probably the route I'm going to go.
