Old 01-23-2015   #1
ryukinevo
Drives: 2003 evo 8
Post More aftermarket/oem parts listed from new build-AMS,Fidanza,Hawk,APR,PTE,FIC,carbon!
Hi evo 8-10/dsm/talon/eclispe owners! Sold a lot of my aftermarket/oem parts from my current evo 8.5 build and this is what I still have for sale, see my itrader feedback! I paid a lot of money through the course of this project; my loss is your gain!
  • Parts are ready to ship after paypal has cleared, usually same or next day! pm for paypal address after agreement to purchase part.
  • PRICES DO NOT INCLUDE SHIPPING OR PAYPAL FEES and I will only charge actual shipping cost with insurance via usps, Fedex, UPS, or Greyhound for the larger items. Please be serious upon purchase before asking for shipping quotes!
  • If a price is out of line with the market prices, do not be afraid to make an offer. However, I have done the research and believe these are accurate evolutionm going rate prices. The worst thing is that I would say no!
    Please contact Scott via pm or cell #
    http://www.hidetext.net/hide/mMaqGfFqy9.gif
    Please see my local craigslist for evo or Honda parts:
    http://desmoines.craigslist.org/pts/4828503965.html
    Flickr for all pictures not displayed in this post:
    https://www.flickr.com/photos/114062...7650374654115/
    Aftermarket evo parts: 3k or less miles unless noted otherwise:
  • Fidanza cam gear (black) (<2K) - $100
  • AMS shifter base bushing kit BNIB - $40
  • Hawk front pads (<2k) - $75
  • Hawk rear pads (<2k) - $75
  • Precision Turbo PTE6262 .82A/R 5 bolt turbine housing - Tirado Custom Coatings gold ceramic coated BNIB (TCC does perfect work, but 3 month wait) - $150
  • FIC fuel injector seals (Used <2K with 2150s) - $20
  • dimple oil drain plug (Used 1 oil change) - $30
  • APR GTC-200 carbon fiber side plate (AA-100048) BNIB - $45
  • MISHIMOTO evo 8/9 radiator hoses (20K, red) - CURRENTLY NOT FOR SALE UNTIL TUNE
    Universal evo parts:
  • ALTEC PRODUCTS Show-N-Go motorized front license plate w/ remote BNIB - $100
  • Rockford Fosgate positive battery terminal (gold 'R' shape, 1 nut was replaced) BNIB - $30
  • Ichibahn valve stem caps (yellow) BNIB - $8
  • Pilot led side marker lights BNIB - $20
  • Passport/Escort Direct Wire Smartcord (79-000041-01 - red) - BNIB $25
  • Lightning Audio 1 farad capacitor BNIB - $50
  • 1/2" 20 x 3/4 oil drain plug BNIB - $10
  • -8AN braided stainless line (w' 1 new Fragola -8 straight fitting (black) not yet installed) - $30
  • 1 PERRIN tbolt 225 clamp - $5
  • 2 BREEZE tbolt 300 clamp - $3
  • 1 BREEZE tbolt 288 clamp - $3
  • 1 BREEZE tbolt 263 clamp - $3
  • Hose Techniques silicone 2.5" 90 degree coupler (red) BNIB - $20
  • Silicone 4" to 3" reducer coupler (black) - $5
  • NASCAR carbon fiber 4" to 3" reducer - $20
  • APC Super White 1157 bulbs BNIB - $5
  • Spider lite led bulbs (red) 7443 BNIB - $20
    oem evo 8/9 parts: 42K or 52K miles unless noted otherwise:
  • evo 8/9 throttle body (52k no sensors with bolts) - $75
  • evo 8/9 radiator (52k, with radiator cap & overflow hose) - $125
  • evo 8/9 flywheel (42k) - $75
  • evo 8/9 O2 housing with spring bolts (42k) - $60
  • evo 8/9 front strut bar - $40
  • evo 8 RR oem carbon fiber wing (Near perfect clear coat, detailed annually until removed, ready to bolt on!) - $275
  • evo 8/9 power steering reservoir (52K) - $30
  • evo 8/9 Gates blue serpentine belt (Mounted 1 time, 0 miles) - CURRENTLY NOT FOR SALE UNTIL TUNE
  • evo 8/9 oil pump balance shaft (42k) - $25
  • evo 8/9 balance shaft (42k) - $20
  • evo 8/9 rear dog bone mount (50K) - CURRENTLY NOT FOR SALE UNTIL TUNE
  • evo 8/9 exhaust hanger (52K) - $5
  • evo 8/9 hood prop - $10
  • evo 8 front bumper duct - $20
  • evo 8 front bumper oil cooler duct - $25
  • evo 8 front bumper long metal bracket - $25
  • evo 8/9 front crash beam brackets (RR) - $25
  • evo 8/9 front engine mount bracket - $15
  • evo 8 bumper Styrofoam LH - $10
  • evo 8 bumper Styrofoam RH - $10
  • evo 8 rear bumper metal bracket - $10
  • evo 8/9 hood release latch - $15
  • evo 8/9 radiator hose (52k still good) - $5
  • evo 8/9 radiator brackets (No rubber) - $5
  • evo 05'/06' ACD computer (mileage unknown) - CURRENTLY NOT FOR SALE UNTIL TUNE
  • evo 8/9 fan control (52K) - CURRENTLY NOT FOR SALE UNTIL TUNE
  • 3 - evo 8/9 O2 sensors (mileage unknown) - CURRENTLY NOT FOR SALE UNTIL TUNE
  • 2 evo 8/9 fuel assembly float (mileage unknown) - CURRENTLY NOT FOR SALE UNTIL TUNE
  • evo 8/9 cd player (25k) - $25
  • evo 8 engine harness (52k, was uncut harness, but due to evolutionm vendor sold undisclosed damaged evo 9 harness - had to cut 1 wire harness and 1 wire needs re-soldered - most likely easy fix!): - $200
  • evo 8 chassis/headlight harness (52k, uncut/unmodified) - $130
  • evo 8 dash harness (52k, some wires patched into for alarm, easy fix!) - $130
  • evo 8 transmission wire harness (52k, uncut, unmodified) - $50
  • 2 evo 9 chassis/headlight harness (SOLD AS IS: evolutionm vendor sold undisclosed damage/modified harness) - $100 each
  • evo 9 dash harness (SOLD AS IS: same above evolutionm vendor) - $100
  • 3 evo 8/9 horns - $15 each
  • evo 8/9 EGR valve (42k with bolts) - $25
  • evo 9 oil pressure switch (42K) - $10
  • evo 8 clutch fork (52k with 2 release springs) - $30
  • evo 8 firewall relay (52k) - $15
  • evo 8 turbo coolant lines - $25
  • evo 8/9 front brake lines (52k) - $20
  • evo 8/9 rear brake lines (52k) - $20
  • evo 8/9 fuel pressure regulator (42k, hose extended) - $30
  • evo 8/9 fuel pressure solenoid (52k) - $25
  • evo 8/9 fuel feed line (42k, hose extended) - $10
  • evo 8/9 undertray (center panel only) - $25
  • evo 8/9 brake dust shields - $30
  • evo 8/9 vacuum bracket (valve cover) - $5
  • evo 8/9 vacuum bracket (large) - $10
  • evo 8/9 wiring bracket (valve cover) - $5
  • 2 evo 8/9 intake manifold brackets (with bolts) - $5 each
SOLD:
  • evo 8/9 oil pump case only (42k)
Aftermarket: (<3k) miles
UNIVERSAL
evo 8/9 oem (42K) or (52K) miles
evo 8/9 wiring/electrical
evo 8 transmission wire harness (52k) - $50
[B]
evo 8 engine harness (52k) - $200
evo 8 dash harness (52k) - $130
evo 8 chassis/headlight harness (52k) - $130
evo 9 chassis/headlight harness #1 - $100 each
evo 9 dash harness - $100
evo 9 chassis/headlight harness #2 - $100 each
ryukinevo is offline   Reply With Quote
Old 02-16-2015   #2
ryukinevo
Drives: 2003 evo 8
Re: More aftermarket/oem parts listed from new build-AMS,Fidanza,Hawk,APR,PTE,FIC,car
Bump!
evo 8 RR oem carbon fiber wing sold!
Old 03-05-2015   #3
ryukinevo
Drives: 2003 evo 8
Bump!
evo 8 transmission harness sold!
Old 03-08-2015   #4
ryukinevo
Drives: 2003 evo 8
Bump!
evo 8/9 throttle body (52k) sold!
Old 03-21-2015   #5
ryukinevo
Drives: 2003 evo 8
Bump!
evo 8/9 fuel pressure solenoid (52k) sold!
Old 05-06-2015   #6
ryukinevo
Drives: 2003 evo 8
Bump!
evo 8/9 oem radiator (52k) sold, who needs parts?
Old 09-12-2015   #7
ryukinevo
Drives: 2003 evo 8
Moved, still have parts, who needs parts?
Old 11-08-2015   #8
ryukinevo
Drives: 2003 evo 8
Post Re: More aftermarket/oem parts listed from new build-AMS,Fidanza,Hawk,APR,PTE,FIC,car
Bump, newly added parts
  • AMS (moroso) aluminum wet sump oil pan (220 miles), w/dimple oil plug - $580
  • AMS intercooler w/ couplers (2k miles before damaged by tow truck driver) - $225
  • Custom Honda battery tray (group 51, 450CCA) - steel, black, w/stainless/aluminum hardware (tray only, battery free to local buyers) - $125
  • catch can (unknown brand) w -8AN lines/valve cover fittings - $125
Old 12-12-2015   #9
ryukinevo
Drives: 2003 evo 8
Bump, who else needs parts?
AMS oil pan sold.
