Old 06-19-2004   #1
Khadgar
Can't Actually Wrench
Ok so I got everythign out I dont need now I have to deal with these two lines from teh firewall, I was hoping to get some advice on where to route them safely too as well, I don't want to halfass anything dealing with flamable gas, I've also heard something about a rollover switch in this area you aren't supposed to disconnect, but I didnt see anything like that in the service manual.
Line 1
Line 2
Thanks for any help!
-Khad
Old 06-19-2004   #2
Enes
Enes's Avatar
sorry my car never had a charcoal canister.. even tho it is a 2g it came that way from factory..
-E
Old 06-19-2004   #3
Khadgar
Did you check your front drivers side corner...that's is where they moved it in the 98-99 years....
Old 06-19-2004   #4
FYI, you linked to the same picture twice.
Old 06-19-2004   #5
Khadgar
Thanks for pointing that out, I fixed it.
Old 06-19-2004   #6
Emcee gsxtc
Emcee gsxtc's Avatar
Is the charcoal canister the huge thing under the battery in most dsm's? I thought about removing it on the 1g but heard bad things, I didnt even want to mess with it on my 2g, but am very interested. I like to reduce vacuum lines, miscellaneous junk etc.
Run your car not your mouth!
Pick Two: FAST CHEAP RELIABLE
Old 06-19-2004   #7
It pulls a CEL on 2Gs and nothing on 1Gs.
here is a pic or 2 of the shit that gets removed with an EGR block off plate
Old 06-19-2004   #8
Old 06-19-2004   #9
Old 06-19-2004   #10
and then yank that can!
Old 06-19-2004   #11
Emcee gsxtc
ALL THOSE vacuum lines on the throttle body too!?!?!?!?!?!?! Wow maybe I will need to that pretty soon then too.
Old 06-19-2004   #12
Khadgar
I pulled all my solenoids too, REALLY cleaned up the firewall up top.
BTW k thx for answering my question AJ. =P
Old 06-19-2004   #13
Kougar
Drives: 06 RSX
The old quest is gettin' this treatment too...EGR Blockoff plate, then take out related parts =)
But my bay might win when it comes to misc. wires/vac lines...
Old 06-19-2004   #14
If you want to see a bare firewall just stop by QPR and take a look at my car, or I can take a picture for you.
Old 06-20-2004   #15
2g Emissions elimination.
Old 06-20-2004   #16
Jacek
Captain J-Sack
can someone explain to me why you would pull this stuff out? is there a gain besides cleaning up your engine bay?
Old 06-20-2004   #17
Khadgar
2lbs and I guess you could mount your battery lower if you wanted.
Old 06-20-2004   #18
Khadgar
I am also thinking of blocking off the coolant lines going to the TB to try and maybe reduce intake temps.
Old 06-20-2004   #19
Black97civic
35mpg
This is what my engine bay looks like after some cleaning up, EGR and all emissions equipment gone, a/c gone, and cruise soon to leave. Also, 1g mas and 1g K&N instead of retarded stock aircan.
Old 06-20-2004   #20
Black97civic
35mpg
n/m
