Old 11-24-2015   #1
Boostedls
Drives: Asti
2002 Mirage Coupe Swapped Evo 4g63t
Hey guys! I thought I'd throw my build on here to see what u guys think. It's a 2002 Mitsubishi Mirage LS Coupe. I've had the car for a couple years now but I finally decided to go ahead with the build. After I sold my Evo8, I decided to start my Mirage build. Since I had a bunch of parts collecting dust I figured why not. I scored on a mirage parts car that the previous owner had done a bunch of stuff done on. So I picked it up and salvage whatever I could.
I'm not done yet but I'm awfully close. A lot of sweat, blood, and tears.
Here's a parts list:
Engine:
Tomie 272 Camshaft
Dual Valve Springs
AC&PS Delete
BS Delete
Wiseco Pistons
Eagle Rods
HAFE Manifold
Garrett GT3076R
Megan Downpipe
Stainless Steel Oil Lines
Kinugawa Water Lines
TiAL 44mm Wastegate
TiAL Q 50mm BOV
Omni 3bar Map Sensor
Jdm Sti 565cc
Aeromotive FPR
DW340lp Fuel Pump
Evo 4 Transmission
ACT Clutch Monoloc
XTD 6puck Clutch
MAP Clutch Fork Stop
STM Stainless Steel Clutch Line
Evo 8 Slave Cylinder
VR4 1 1/16 Brake Master Cylinder
STM Oil Cooler and Thermostat Delete
TRE FWD LSD Transfer Case
Evo 4 Aluminum Radiator
Evo 4 Radiator Upper Mounts
Misimoto Upper Radiator Silicone Hose
Evo Intercooler
Interior:
Evo 6 JDM Recaro Seats
AEM Digital Boost Gauge
AEM Digital WideBand
Exterior:
Stock for now
Suspension:
5 Lug Swap
Evo 4 Knuckles
Evo 8 Brembo
Evo 8 Rotors
Evo 8 Control Arms
Evo 8 Front Sway Bar
Technica Stainless Steel Brake Line
Mirage Non-PS Manuel Steering Rack
Ralliart Trailing Arms
Custom Toe Arms
Megan Camber Arms
Whiteline Rear Swaybar
ASR Subframe Brace
Beaks Lower Tie Bar
Aluminum LCA
Cusco Rear Strut Bar
KYB AGX
H&R Springs
Wheels:
Evo 9 SE BBS 17x8
Things I still need to do:
Custom intercooler pipings
Weld and install IAT bung to run speed density
Weld WideBand bung
Custom axle back
Wirings
Ecu flash
Tune
Before: stock 1.8 4g93 t25 turbo
Parts car next to My coupe
Some random pictures over the years:
Removed the PS components and rack and replaced it with a Mirage non-powerseteering rack
Started on the EVo 5 lug front Brembo swap and Stainless steel brake lines
Upgrading the stock Master Cylinder to utilize the bigger brakes
Removing and replacing the stock Mirage trailing arms with 04-06 ralliart. Sadly I won't be running Brembos for the rears unless I get a custom bracket made.
Installing my Kyb AGX with H&R springs
Rear end since I'm not going AWD anytime soon
Dropped my gas tank and installed my DW340lp Fuel Pump
I picked up these JDM Evo 6 Recaro seats form Iowa
Straight bolt in no modification required.
Picked these up these gauges at DB to go along with the interior
Started getting the motor ready to drop in. Don't be confused, that was the g64 eclipse trans I was going to used to stay fwd instead I picked up the modded transfer case so I can utilize the Evo trans.
Turbo setup I'll be going with for now. Garrett gt3076r
Dropping the motor in
Installing my modded TRE transfer case
Installing the stock Mirage crossmember and Evo axles
This is its most current state
It's different but I hope u guys like it! Plan is to get it done and ready to roll out by spring time.
Boostedls is offline   Reply With Quote
