Old 06-02-2016   #1
jeremy1375
jeremy1375's Avatar
I need 2 junk front axles for 1ga ASAP
It's for a 1990 awd 1ga. I'm pretty sure fwd axles would work too.
At a minimum, I need the spindle side of 2 axles to bolt into the spindle to support the bearing.
I tried rolling my shell down the driveway without front axles and the bearing broke on one side - causing the wheel to fall off. Now it's stuck in the middle of my driveway.
Hoping to find something cheap.
Nothing is exactly as it seems, nor is it otherwise.
Old 06-02-2016   #2
b00sted_spyder
Re: I need 2 junk front axles for 1ga ASAP
Use a long big bolt with 2 large washers and a nut. 1 washer on the outside and the other on the inside.
Old 06-02-2016   #3
jeremy1375
jeremy1375's Avatar
^That's a much better idea. Thanks
