Old 08-25-2016   #1
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Piston Sizing
I'm pretty sure I know the answer but just want to be sure before ordering pistons and having to exchange them.
I'm building a 6 bolt block and I'm using an I beam rod that uses a 22mm wrist pin. Do I use a 7 bolt piston or a 6 bolt piston? Is the only difference the pin size between the 6 bolt and 7 bolt? Right now I believe I need a 7 bolt piston to achieve the 22mm pin diameter.
Thanks
BW8776, e-85
