Old 09-13-2016   #1
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Evo 8/9 Partout: Aftermarket and OEM, Tons and Tons of Parts!
Evo 8/9 Multiple Evo Partout:
Ad is self explanatory, everything is in good-great shape unless stated otherwise. I'm located in Mankato MN. If its not listed I more than likely dont have it.
Cell is 5072152103.
Thanks
Chris
Evo 8/9 Engine/Drivetrain/Turbos/Manifolds/Cams/Aftermarket
•Evo ACD Tcase 60xxx miles - $1300 shipped
•Evo ACD Tcase 100xxx miles - $1200 shipped
•ETS BB 6266 Gen 2 Vband Turbo Kit (Standard facing Turbo, Manifold, DP, LICP, Intake, Lines. Everything needed for install) - $3600 shipped
•Buschur Double Pumper $500 shipped
•Walbro 255 with OEM Fuel Pump Hanger - $140 shipped
•OMNI 4bar MAP Sensor - $80 shipped
•DNP Coated Tubular Manifold (2k miles) - $700 shipped
•Frontline Fab Rear Diff Cover BRAND NEW - $450 shipped
•QuarterMaster Twin Disc Clutch (Race version) with Hydraulic TOB - $1200 shipped
•ACT HDSS Extreme Pressure Plate/Streetlite Flywheel (Perfect shape! 200 miles on kit, bought new, swapped out for Exedy Twin) - $700 shipped
•ACT Lightweight Flywheel - $200 shipped
•Braided Clutch Line - $55 shipped
•ARP Headstuds and Main Studs - $80 shipped
•3 Good Manley Turbo Tuff Rods/Manley Pistons - $450 shipped
•3 Good Oliver Rods - $300 shipped
•Solid Front Motor Mount - $45 shipped
•Megan or similar brand Exhaust Tubular Manifold - $100 shipped
•(3) Turbo Intakes - PM for pricing and pics
•MAF/K&N Filter - $60 shipped
•CF Spark Plug Cover Evo 8 - $80 shipped
Evo 8/9 OEM Parts/Sensors/Odds and Ends ETC.
•Box of Like New Timing Components – PM Me
•(2) Crank Sensors - $55 shipped
•Knock Sensor - $50 shipped
•(2) Oil Pressure Switches - $20 shipped
•(2 sets) Front Axles - $300 shipped for a set or $150 each.
•Rear Axles Set - $300 shipped
•Evo 8 Wire Harness - $280 shipped
•Evo 8 Valve Cover 8/10 shape - $200 shipped
•(3) OEM Driveshaft in very nice shape - $100 each plus shipping
•Master Cylinder - $75 shipped
•(2) OEM Exhaust Manifold - $60 shipped
•OEM O2 Housing with O2 Sensor - $50 shipped
•(5) OEM Intake Manifold - $75 shipped
•OEM TB - $50 shipped
•DSM BOV - $40 shipped
•OEM Fuel Pump Hangers NO PUMPS - $80 shipped each
•OEM Starter - $90 shipped
•(2) OEM Alternator $90 shipped
•Motor Mount Bracket to Block - $80 shipped
•(2) LIKE NEW OEM Evo 8 Water Pump (Idle time only) - $120 shipped or best offer
•(3) OEM Serpentine Belt Tensioner - $100 shipped
•(5) OEM Crank Pulley - $50 shipped
•Accessory Belt Idler Pulley - $35 shipped
•(2 sets) OEM Balance Shafts - OFFER
•Evo 8/9 All 16 Rockers - $200 shipped
•(2) Cam Sensor Housing Evo 8 - $30 shipped
•(4) OEM Cam Gears - OFFER
•OEM Evo 8 Cams - OFFER
•(2) Oil Dipstick with Tube - $30 shipped
•(3 sets) OEM Evo 8/9 Ignition Coils - $50 shipped
•(3) OEM Fuel Rail/FPR - $40 shipped
•(2) Fuel Pressure Regulator/Line - $20 shipped
•(2) OEM Radiator and Fan/Module Assembly - $160 plus shipping
•Radiator Fan/Module - $100 shipped
•Radiator Fan no Module - $50 shipped
•OEM Radiator Pipes – PM what ones you need
•(6 sets) OEM Radiator Mounts – OFFER
•(2) Evo 8 Coolant Hard Pipe and Thermostat/Sensors - $100 shipped
•Tons of AC Lines (Lmk what you need) - OFFER
•OEM Motor Mounts – PM with what you need
•(6) AC Compressor Bracket - $35 shipped
•Power Steering Bracket - $40 shipped
•Coolant Reservoir - $25 shipped
•(2) Power Steering Reservoir - $25 shipped
•(2) Front Windshield Wiper Motors - $30 shipped
•(2) ABS Module - OFFER
•Evo 8 Lower Timing Cover - $40 shipped
•OEM Clutch Slave - $50 shipped
Evo 8/9 Suspension/Brakes/Wheels and Tires/Aftermarket
•LIKE NEW Volk RE30, 18x9 +35 with Toyo 265/35/18 (Wheels and Tires only have a few hundred miles) - $3400, wheels alone are $3600 new
•(2) Cusco Front Sway Bar - $200 shipped
•(2 sets) Drilled and Slotted Rear Rotors- $60 picked up
Evo 8/9 OEM Suspension Parts
•(2) OEM Front Strut Bars – OFFER
•(3) Steering Columns with Ignition Switch/Key - $80 shipped each
•OEM Rear Control Arms – PM with what ones you need
•Front and Rear Wheel Knuckles/Hubs - PM what you need
•Evo 8/9 Front Subframe - $80 plus shipping
•OEM Mustache Bar - $100 shipped
Evo 8/9 Interior/Seats/Consoles/Trim ETC.
•Evo Recaros F&R Custom Seats with Carbon Fiber Designed Leather and Heated Front Seats. Comes with Custom Shift Console and Center Console and all wiring needed. Driver front bolster has some play in it. $800 picked up
•Evo 8 Blue Recaros Front and Rears Tough Shape - $250 picked up
•CF 3 Pod APillar - $50 shipped
•Center Console - $50 shipped
•Radio/Climate Control Bezel - $30 shipped
•Lower Cubby for MR/RS Gauges - $30 shipped
•Glovebox - $40 shipped
•(3)Gauge Cluster Bezel - $25 shipped
•Evo 8/9 Interior Pieces (I have 3 cars worth or more) - PM what you need
Evo 8/9 Electronics/ECUs/Gauges/OEM Electonics
•Evo 8 Gauge Cluster with Blue Bezel (93k Miles) - $140 shipped
•Greddy Boost Gauge - $120 shipped
•Prosport Voltage Gauge -$40 shipped
Evo 8/9 Exterior
•OEM Rear Bumper Tarmac Black - $300
•OEM Rear Bumper Weightless White - $250
•Evo 9 WW GSR Front Lip Great Condition - $150
•Evo 8 HID Ballast - $60 shipped
•Evo 8 RS Driver Headlight for spare parts, pm for info - $100
SOLD
•GT28 Complete Turbo Kit - SOLD
•Evo 9 Wrinkle White Valve Cover (two cracks but still seals fine) - SOLD
•SSP Texas Evo Catch Can/Small Battery Tray Kit with Powder Coated Teal Valve Cover (8AN fittings/lines to CC) - SOLD
•Shep Stage 3 Ultimate Ratio Trans, 4.11s (Every option Shep offers is in this trans, less than 1k miles) - SOLD
•FIC 2150cc Injectors (Comes with Resistor box delete plug - SOLD
•AMS Lightweight Cross Member - SOLD
•Evo 9 OEM Intake Manifold/Throttle Body (No Sensors) - SOLD
•Evo 8 Cylinder Head (Complete) with GSC S2/GSC Beehive Valve Springs/Titanium Retainers - SOLD
•ETS 3.5" FMIC with ETS stencil - SOLD
•ETS UICP (coated black) with purple Tial Q BOV - SOLD
•Curt Brown Ported Intake Manifold with 70mm Flange and Full Blown 70mm Throttlebody - SOLD
•CF Cam Cover Evo 8 - SOLD
•Torque Solutions Passenger Side Mount - SOLD
•AEM Methanol Kit - SOLD
•Front and Rear Passenger Doors Tarmac Black - SOLD
•Passenger Side Mirror Tarmac Black - SOLD
•Apexi AVC-R EBC - SOLD
•AEM Digital Air/Fuel (Black Bezel) - SOLD
•AEM Digital 50psi Boost Gauge (Black Bezel) - SOLD
•Lower Cubby for MR/RS Gauges - SOLD
•Shifter Console - SOLD
•OEM Fuel Pump Hangers NO PUMPS - SOLD
•OEM Starter - SOLD
•5 Speed Shifter Cables - SOLD
•Box of Like New Timing Components – SOLD
•Evo 8 Engine Longblock Oil Pan - Valve Cover (100xxx Miles) - SOLD
•Mini Battery Tray Coated Purple - SOLD
•HDSS Pressure Plate - SOLD
•OEM Flywheel - SOLD
•Radium Catch Can for Evo 8 Passenger Side Mounted - SOLD
•Power Steering Pump - SOLD
•Front Axles - SOLD
•Rear Axles Set - SOLD
•OEM Driveshaft in very nice shape - SOLD
•OEM Intake Manifold/TB - SOLD
•OEM Alternator - SOLD
•OEM Serpentine Belt Tensioner - SOLD
•OEM Crank Pulley - SOLD
•Accessory Belt Idler Pulley - SOLD
•OEM Fuel Rail/FPR - SOLD
•OEM Motor Mounts – SOLD
•Power Steering Bracket - SOLD
•OEM Front Strut Bars – SOLD
2006 WW IX RS 396/404 - SOLD
Old 09-25-2016   #2
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: Evo 8/9 Partout: Aftermarket and OEM, Tons and Tons of Parts!
List updated!
Old 10-04-2016   #3
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Bump list updated, make offers on whats left!
Old 10-12-2016   #4
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Bump make offers
Old 10-25-2016   #5
Dsm_kidd
Dsm_kidd's Avatar
Drives: 91 Talon Automagic
Evo 8 front seats, pictures?
651-338-4920
Dsm_kidd is offline   Reply With Quote
Old 11-09-2016   #6
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
651-338-4920
I've got one passenger seat left as of now lol. And a set of blue Evo 8 recaros coming shortly. Sorry just saw this.
Chris
