Old 03-26-2017   #1
M1L3S
M1L3S's Avatar
Drives: 99Gst
Welded center diff?
Who here has done it?
Thoughts on it?
Any auto guys have it done?
Anyone with it, willing to give a guy a ride in there car to see what its like having it....
M1L3S is offline   Reply With Quote
Old 03-26-2017   #2
Fran05
Drives: DSM
Re: Welded center diff?
I had a welded center on my 1g. It forces 50/50 split all the time. This should, in theory, make your drivetrain stronger, but driveability def suffers. I could feel it bind up when making sharp turns in the parking lot.
Fran05 is offline   Reply With Quote
Old 03-26-2017   #3
It sucks on the street, I also believe it directly contributed to splitting my transfer case in half at the Shootout one year. Unless you're doing a drag only car, it's a waste of time, you're better off with a 4-spider diff.
Old 03-29-2017   #4
dogwhistle
dogwhistle's Avatar
I didn't mind it but made parking a bitch. Also increased tire, and bushing/tie rod wear in suspension components however, rain driving was a little sketchy, and snow was all out fun. That said, unless your power levels/driving style and environment call for it, not sure it's for you.
-Adam
aneujahr@maperformance.com
Old 03-29-2017   #5
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
I have a welded center diff in My 2G auto. The only time I notice it is backing out of my driveway or pulling into a parking spot. I also like to be able to kick the back end out around corners. I don't drive my car in the rain or snow so I can't really comment on that. It is going to be harder on drive train parts. There really isn't a affordable 4 spider option for autos so welded is the way to go.
11.35 @ 120mph
Old 03-29-2017   #6
CarPsyco84
CarPsyco84's Avatar
I personally think it breaks alot of stuff. I've had both, the only transmissions I've ever had trouble with were welded center diff ones... sheared the hollow shaft that drives the front diff, sheared all the teeth off the center diff cause the heat from welding softened the temper on the gear. Then I went to a factory 2 spider center and did not have another issue on a 50 trim car.
If you watch the video's of the welded diff guys in slow mo, they have this driveline slamming that occurs when each axle slips, then takes up all the slack then it makes the other axle slip, that hop cannot be good for anything.
-When in doubt, Moar RPM.
Old 03-31-2017   #7
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
I have a welded center diff in my auto. The only time I notice it is when I am turning sharp both reverse and forward.
If you can't afford to buy an EVO, might as well beat an EVO
Boomdeeze is offline   Reply With Quote
Old 03-31-2017   #8
^that. Cheap and effective
Old 04-06-2017   #9
M1L3S
M1L3S's Avatar
Drives: 99Gst
Thinking ill hold off on welding this one. Ill save it for another auto. If anyone has a spare auto trans they are selling. Ill buy it!
