Old 07-02-2017   #1
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Evo 8/9 Mega Partout
EvoTuna’s Mega Partout,
Enjoy!! Call or text! Located in Mankato MN 56001
Chris 507-215-2103
Engine/Valve Cover/Motor Mounts:
-Curt Brown 2.3 Shortblock Manley Turbo Tuff Rods, Wiseco 1400HD Pistson OEM 100MM Crank (NO CORE REQUIRED, BRAND NEW) -$4000 shipped
-Curt Brown Built & Port Evo 9 Head (BRAND NEW) - $2200 shipped
-Saikou Michi Dual Sealed Catch Can setup – 8AN Rear Can & 10AN Front Can (LIKE NEW) - $130 shipped
-Setrab Oil Cooler Setup with AN Lines and Fittings (LIKE NEW) - $300 shipped
-Torque Solutions Motor Mounts (Trans, Pass, Rear and SICK Performance Front Mount) ALL 4 FOR 5speed (BRAND NEW) - $370 shipped
-STM Power Steering Kit Delete (Lines, Fittings, Reservoir, etc BRAND NEW) - $300 shipped
Drivetrain:
-TRE Fully Built Max Lock Rear Diff (BRAND NEW)- $1600 shipped
-OEM Rear Diff (55k miles and great shape) - $700 shipped
-Curt Brown Ceramic Wheel Bearings (BRAND NEW) - $1650 shipped
-AWD Motorsports Aluminum Driveshaft w/Beatrush Solid Bushings (Great shape) - $900 shipped
-STM Full Stainless Clutch Line – Master to Slave (BRAND NEW) - $50 shipped
-STM Clutch Pedal Stop - $30 shipped
Turbo/Intercooler/Piping-Mini Battery/Intake/Exhuast:
-Shorai Lithium Battery & Charger (Brand New) - $300 shipped
-Custom MP Fab Aluminum Battery Tray for above battery (Brand New) - $150 shipped
-MAP REV3 Intake Manifold Adonized Black with Curt Brown Welded on 70mm Flange. Also comes with P2R Thermal Intake Manifold Gasket (BRAND NEW) - $475 shipped
-S90 Throttle Body Coated Wrinkle Black w/P2R Thermal Throttle Body Gasket (BRAND NEW) - $200 shipped
-Custom Intake (4” Green Air Filter, 4” Vibrant Velocity Stack to use with above filter, 3.5” to 4” 45 Degree Silicone Coupling for Stock Frame Turbo with Heat Shield (BRAND NEW) - $140 shipped
Radiator/Fuel/Ignition:
-SparkTech NON CDI COP (Great shape) - $425 shipped
-Magnecor Ignition Cables - $40 shipped
-Areomotive Fuel Rail - $130 shipped
-Wilson Manifolds D Rail Fuel Rail (BRAND NEW) - $140 shipped
-Spoolin-Up Injector Bypass Plug (BRAND NEW) - $10 shipped
-Fuel Lab Pressure Gauge - $25 shipped
-FIC Quick Release Fuel Injector Plug Connectors (BRAND NEW) - $25 shipped
Suspension/Brakes/Wheels:
-Black Enkei RPF1 Wheels 17 x 8.5 w/Hankook Ventus V12 Evo 255/40/17 Tires (LIKE NEW) - $1000 picked up
-Fortune Auto 500 Coilovers Swift Spring F-10k R-8k & Radial Bearing Upgrade (BRAND NEW) - $1300 shipped
-JIC Custom Built Coilovers (3K miles, great shape) - $1200 shipped
-STM Hydraulic Staging E-Brake Kit (BRAND NEW)- $500 shipped
-Girodisc Two Piece Rotors (1k miles, great shape) - $1000 shipped
-MP Fab Custom Aluminum Front Cross Member (BRAND NEW) - $200 shipped
-DC Sports Titanium Front Strut Tower Bar - $500 shipped
-DC Sports Titanium Rear Strut Tower Bar - $400 shipped
-BWR Billet Rear Lower Control Arms (BRAND NEW) - $275 shipped
-Tanabe Front Sway Bar w/ New Bushings - $250 shipped
-Perrin Rear Sway Bar End Links (BRAND NEW) - $110 shipped
-Whiteline Front & Rear Sway Bar Lateral Locks (BRAND NEW) - $35 shipped
Exterior/Interior/Gauges:
-Heatshield Fitted Windshield Sunshade (BRAND NEW) - $30 shipped
-Custom Hext Fitted Floor Mats Front & Rear (BRAND NEW) - $60 shipped
OEM BRAND NEW PARTS:
-Oil Pan (BRAND NEW) - $170 shipped
-Mivec Solenoid (BRAND NEW)- $325 shipped
-Mivec Cam Gear (BRAND NEW) - $300 shipped
-16 Rocker Arms (BRAND NEW) - $325 shipped
-Oil Filter Housing Evo 9 (BRAND NEW) - $110 shipped
-OEM Evo 9 Coolant Hardpipe (BRAND NEW) - $80 shipped
SOLD:
-FP Manifold Ported and Coated by Detective Coatings w/Stud Kit (BRAND NEW)
-MAP H11 Ultimate Duty Headstuds (BRAND NEW)
-Kiggly HLA (Brand New)
-OBX Aluminum Alternator & Water Pump Pulley Kit (BRAND NEW)
-ToxicFab Custom Ti Cam Angle Sensor Shield (BRAND NEW)
-TRE Stage 3 Trans Ultimate Ratio (BRAND NEW)
-Shep Stage 3 Trans (All of the Options, 4.11, REM Gearset, Billet Output Shaft ETC, BRAND NEW)
-Shep Built NON ACD Tcase with Quaife LSD (BRAND NEW)
-Exedy HD Twin Disc Clutch (BRAND NEW)
-ACT Monoloc (BRAND NEW)
-Buschur 4” FMIC Anodized Black (Great shape)
-ETS UICP Tial Flange Anodized Black (Great shape)
-ETS LICP Heat Wrapped (Great shape)
-CBRD Slim Radiator w/Fan and Piping (Great shape) and Torque Solutions Radiator Brackets w/ OEM Bushings (Brand New)
-OMNI 4Bar Map Sensor and IAT Sensor (BRAND NEW)
-Techna Fit Stainless Steel Brake Line Kit Front & Rear (BRAND NEW)
-Hotchkis Rear Sway Bar w/ New Bushings
-Tactrix 1.3 Tuning Cable
-AEM Digital Wideband Gauge (BRAND NEW)
-AEM Digital Boost Gauge
-AEM Digital Oil Pressure Gauge
-Mynes Hood Dampers (Great shape)
-GSC R2 Cams (BRAND NEW)
-Topline Revised Lifters
-Evo 9 Valve Cover Powder Coated Wrinkle Black
-EvoDan Tensioner Pulley Delete – Alternator Adjustment Rod (BRAND NEW)
-EvoDan Idler Pulley with Ceramic Bearing & Ti Bolt (BRAND NEW)
-Detective Coatings Powder Coated Parts: T-Stat Housing (Top & Bottom), AC Pump Bracket, PS Pump Bracket, Cam Sensor Housings
-STM Clutch Fork Stopper (BRAND NEW)
-FP Zephyr Coated by Detective Coatings with Black Tial MV-S Wastegate, O2 Housing (Coated by Detective Coatings/Dump Tube, Oil Line etc (BRAND NEW)
-Torque Solutions Poly Exhaust Hanger Kit (BRAND NEW)
-Custom Fuel Pump Assembly – Modded Walbro 450 w/ 8AN Feed & 6AN Return Fittings and Fuel Line (BRAND NEW)
-Custom Fuel Lines – 8AN Feed & 6AN Return (BRAND NEW)
-Orange Brembos Powder Coated and Rebuilt by Detective Coatings (BRAND NEW)
-Whiteline Front Sway Bar End Links
-Nagisa Auto Fender Braces (BRAND NEW)
2006 WW IX RS 396/404 - SOLD
