Old 07-18-2018   #1
CarPsyco84
CarPsyco84's Avatar
FS: 1g 600ish whp awd part out
So sawing my motor in half was the last straw. I am getting out of dsm's and moving on to bigger and better things. My failures are your boon's. I have a multitude of parts that need to go to good homes. Prices are all OBO.
First stuff is almost brand new, only a couple hundred miles on this:
2150cc Hi-Z FIC injectors have the data sheet/link info/plug&play -sold
Fluidamper, still have the box and the certs -sold
FuelLab 81831-1 black, 6 micron fiberglass -sold
Zaklee Clear timing belt cover -sold
Freshly reworked bolt-on O2 w/tial 38mm, has a 3" marmon flange? -sold
Southbend SS-X clutch kit 6puck un-spring clutch disk with (2700 lb) pressure plate, - $200 dropped
***This stuff has approx 1k miles in like new condition
ETS race 4" Intercooler back door -sold
FP Black with ported exhaust housing journal bearing (will come with water and oil lines everything to bolt up -sold
FP 4" cast intake tube/filter, no extra lines to it, could add some if desired - $50 - dropped
17" x 9" +45 Bronze Enkei RPF1's with 255/40/17 ZII star spec's, barley worse the nubs off the tires, wheels were brand new when I got them. Can give you the spacers I ran to make them fit a 1g if desired. -$1400 - dropped
***Other used items:
Muellerized JiC's absolutely awsome on these cars and no longer available. - sold
Shep stage 3 w/4 spider 91-94 AWD trans. Always ran the OEM evo 6spd fluid. -sold
REEF street intake (handmade prototype only 3 or 4 exist better than the others) - sold
ACT street light flywheel $50 - dropped
23 Spline Transfer cases $100 (got 2)
22 spline Transfer case (alum headed one) $80 - dropped
L19's -sold
External Oil cooler set up with push lock lines (comes with ported ofh and everything else to make it work) -sold
3.5” catback ss exhaust with magnaflow muffler $125 - dropped
Carbon Hood w/Vent $100
New to list:
ARC-2 Box with plug and play wiring kit and bracket $200
6 bolt head with Evo beehive valve springs and retainers and BC280s $350
I havea stock 6 bolt heads $100
ACE 140 Amp Alternator, has 100 miles on it $60
1G green top CAS $40
1G coil with block bracket I rewired the power wire with larger wire to lower the resistance to the primary $40
1G ignition coils (got 2 more) $20
Got a bunch of other odds and ends as well, like, couplers, water cooled OFH, couple stock 6 bolt oil pans.
Free stuff:
PTE 3076r BB with blown bearings, pretty sure the shaft is bent, housings don't look wrecked.
Have 3 oil pump plates, 1 was brand new before the carnage, 1 came from a running engine (not mine).
Various timing system parts, have at least 2 good tensioners, idler pullies, tensioner pullies,
Got a new water pump, and a used one, neither leaked.
1 end cover with a newer seal in it.
Stock intake manifold.
NGK Plug wires
Non-EEPROM ecu
All the spark plug options you could ever want. BPR8es, br8es, br7es, bpr7es, br8eix
Almost new manual AWD starter plate
Got various pullies and timing covers I just want gone.
Text/call me at 651-245-2218.
-When in doubt, Moar RPM.
Last edited by CarPsyco84; 09-13-2018 at 08:40 PM.. Reason: additions and price drops
Tags
1ga, awd, fp black, part out
