Old 07-20-2004   #1
Please make additions to my list where needed:
Difference between the 1G MT & ATs----
ECU
Injectors
Cams
Turbo
Also, are there any difficulties with swapping a '91 MT setup into a '92?
Thanks!!
Old 07-20-2004   #2
flywheel
pedal assembly
shifter cables
shifter assembly
clutch hydraulic assemblies and lines
brake pedal
center console shifter trim plate
clutch start safety switch
Old 07-20-2004   #3
The exhaust manifold is different too, it is shifted to the side 1". Just put on a 2g one and you are set.
Old 07-20-2004   #4
Is there any difference between the 4 bolt AT rearends and the 4 bolt MT rearends?
Old 07-20-2004   #5
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Ratios a little different from what I remember. My car is originally an AT. One key thing is to get the shifter and linkage right, my fifth and reverse gears are really close to passenger side of the console which makes it interesting for faster shifting.
Also I have to have a small shim in between my crank and flywheel to adjust for differences in all that old AT stuff.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 07-20-2004   #6
Yep, the rear end is way off. You will need to replace that too. I think you can just replace the gears too.
